03-23-2013, 05:19 AM | #1 |
Quarry Creeper Join Date: Aug 2009 Location: Corner of get a map and F- off!
| MOA, Mismatch ESCs ok?
On an MOA, is it ok to use mismatched ESCs, say an FXR and a Micro? Thanks!
03-23-2013, 06:46 AM | #2 |
| Re: MOA, Mismatch ESC's OK?
I've done it with mixed results. If you're within a brand (say Castle ESC's) the differences can be fairly small, but different brands will likely be noticeable but may be drivable. I had a CC ESC in front of my 2.2 and a FX-R in the rear, I was running a Futaba 3PM-x & WantAmix. It was almost impossible to get them even in operation. Using a hacked GT3B, 4PL, etc. may have been easier. I would recommend using similar ESC's front & rear, but it can work if you mix & match. |
03-23-2013, 10:34 AM | #3 |
| Re: MOA, Mismatch ESCs ok?
Ok Charlie, let me pick your brain a bit then. I'm having issues with my smashed FXRs. I can't get one to arm up. The one on the bottom constantly strobes, like it's searching for a signal. The one on top armed up no problem. This problem is out of the blue as well. Calibration didn't work. It didn't even recognize that I was trying to calibrate. I am soooo sick and tired of these FXRs. I have BRXLs on the way. I am done, but the rig is a paper weight until I get them in. Thanks in advance. Jeff |
03-23-2013, 10:40 AM | #4 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
why not one esc and a punk dig?
03-23-2013, 10:45 AM | #5 |
| Re: MOA, Mismatch ESCs ok? |
03-23-2013, 11:04 AM | #6 |
Oh, and if this matters, I can't get either FXR to pop up on the Hotlink. The Hotlink has only one green LED lit. WTF am I doing wrong? Really want to shoot these FXRs.
MOA, Mismatch ESCs ok? - Similar Threads | ||||
Futaba 3PM + dual ESCs + MOA - Settings?? | sweli | Electronics | 11 | 02-01-2010 04:28 AM |
diferents escs in a moa?? | sglogar | Electronics | 4 | 08-05-2009 05:50 AM |
