05-24-2013, 04:33 PM | #21 |
Newbie Join Date: Feb 2010 Location: Germany
| Re: Integy Comm Lathe
don't forget to clear out those shavings with compressed air or a small brush!
05-24-2013, 05:24 PM | #22 |
| Re: Integy Comm Lathe |
05-24-2013, 07:32 PM | #23 |
Rock Crawler Join Date: Oct 2012 Location: Casper
Still looks like that tool is rotated 90deg clock-wise (on it's side), to me. Somebody else mentioned it, as well. Am I just seeing things? Or is this tool designed this way?
05-24-2013, 07:46 PM | #24 |
Pebble Pounder Join Date: Sep 2008 Location: n.e.pa
this is the best info you can find on the net. RC Motor Black Book - HobbyTalk this is what most read to get to where we are now with what we know and refer to. |
05-27-2013, 07:53 PM | #25 |
Quarry Creeper Join Date: Jun 2007 Location: Concord nh
Hey not to get this thread off topic but I found this comm lathe http://rchobbies.com.au/store/produc...876db990462337. I was wondering if it was any good I found one for a lot less than the price shown on that site
05-27-2013, 08:34 PM | #26 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
They work but are a pain to get used to and lots more can go wrong....and often you can do little to stop it as its on auto. I have one.....I think I used it twice and was like, F this.... Later EddieO |
05-27-2013, 09:27 PM | #27 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
Wow, didn't know there is some movements in my thread.... @laxjj14 - the website that you found the lathe is a bit suspicious as if you decide to buy it, they will tell you there is no stock.... I tried them with the 3racing CVD for SCX10 and got same result... @KJ10 - I think the tool is fitted correctly, but I may try to fit it 90 deg and try again. @activethunderrc - Yeah I got lots of great info from there. Ok, I have a question, when you finish cutting the comm, do you need to run the blade or knife between the comm segments to clean up the blur? I found that its rather hard to do that.... Maybe I am still cutting too thick... |
05-27-2013, 09:32 PM | #28 |
The back side of a exacto works well.....its thicker and doesn't float out of the slot and mark the comm as easy. I only do it if there is a lot. Typically when you run it washes them away. I do blow mine out with air, but make sure your compressor doesn't let water through....water will muck it up. Later EddieO |
05-28-2013, 09:45 AM | #29 |
05-28-2013, 07:42 PM | #30 |
Thanks for the tips guys... I always use the sharp side of the exacto knife and skid off to the comm surface and have to redo it..... Luckily I have only cut one comm that's is from a good motor. The rest is from scarp armature.... |
05-28-2013, 07:57 PM | #31 |
Rock Crawler Join Date: Sep 2009 Location: dartmouth ns
I also use the back side of an X-acto blade then i follow with the tip of a ball point pen. It smooths the edges of the comm. Was a huge part of thursday night ritual motor maintenance before brushless came along |
05-28-2013, 08:58 PM | #32 |
Yeah, back side of a blade, or even your fingernail. Fingernails are softer and don't damage the surface if you slip. No ball point pen for me, I want instant on/off for the segments. |
Integy Comm Lathe - Similar Threads | ||||
Comm lathe... | nd4spdbh | Electronics | 8 | 08-02-2005 12:09 AM |
