09-16-2006, 09:48 AM | #1 |
Rock Stacker Join Date: Aug 2006 Location: Co. Durham U.K
| Realy cheap ELECTRONICS
Heres a website with super cheap stuff most f its for planes but there is things like: 6ch transmitter and reciever with crystals for $32 !!!!! loads of brushless motors reduction boxes normal silver can motors http://www.bidproduct.com/part/Produ...CTRONIC_1.html I have had stuff from them before and the delivery is very fast from Honk kong it took just under a week for my RX to be delivered. |
09-16-2006, 10:43 AM | #2 |
| just checked it out, great prices, now all i need is info on which one of those bl motors and esc would work on a crawler?
09-16-2006, 11:50 AM | #3 |
I think you need one with 28mm diamiter and the lowest RPM/V and for an ESC you will need the same or a bit less working current of the motor. so i think the bes for a clod would be: two of http://www.bidproduct.com/part/Produ...0MOTOR_13.html and one http://www.bidproduct.com/part/Produ...S%20ESC_2.html and for a single motor set up you could probly use the same motor with the 20A ESC. Im not realy shure though. Heres a bigger motor with a 28mm diamiter but you will need a bigger esc and it spins faster. http://www.bidproduct.com/part/Produ...w_MOTOR_1.html |
09-17-2006, 12:45 AM | #4 |
Rock Crawler Join Date: Mar 2005 Location: Murrieta
I emailed the manufacturer of those motors to see whick one will work well in a truck.( fast one for me not a crawler)
09-17-2006, 01:11 AM | #5 | |
Pebble Pounder Join Date: Sep 2006 Location: SW Charlotte
09-17-2006, 05:37 AM | #6 |
I just ordered two 27 MHz AM receivers. Figured for $3.00 each, how bad can they be? Total with shipping was $11.00. I'm not expecting Futaba/JR quality, but if they work in the first place, I saved a bunch o' money. The speedos they have are all airplane speedos. No reverse. Some of the batteries look intriguing. If I were a lipo guy, I'd hop on some of the 2200 11.1's. The 22-20 outrunner looks like it would work, and for the price, I thought about it, but I'd rather have a Revolver. Having a spare outrunner would make me need to build yet another rig |
09-17-2006, 09:23 AM | #7 |
Cool those recievers work fine as there the ones i got like you say there not brand name quality but for the price there realy good i think.
09-17-2006, 09:59 AM | #8 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
Does anyone know the specs on the servos?
09-17-2006, 10:11 AM | #9 |
Yea there at the bottom. Non of them are any good for crawling there just rc plane ones the most powerful has 1.5kg/ cm where as an MG995 has 15kg/ cm
09-17-2006, 10:26 AM | #10 |
On the outrunners, the blue ones all have 3.2mm shaft. The gold ones have 3mm shaft. http://www.bidproduct.com/part/Produ...0MOTOR_10.html It would mount up with a motor plate at the very least. These motors look exactly like the junker ones off ebay. Horrible finish, small single front bearing, lots of play in the rotor. Laminations are probably a mile thick (bad efficiency). As I said in another thread, Maybe I have seen a bad representation of the motors. It would be worth a shot getting one to try out though. |
09-17-2006, 04:55 PM | #11 |
You generally get what you pay for with electronics, and pay for what you get. While you may get a motor that will work, it'll be a cheese-dick motor that will eventually fail because it's operating too close to its limit. The Axi, Park and Revolver motors (all around $60) are known quantities that perform. If I were building a foamie airplane that I knew I was going to lawn-dart, that would be the motor I'd go with. But something that's going to be in my truck for years, I want a good one right off the bat. The receiver, either it works or it doesn't. I'm never going to be more than 50 feet away from the thing anyway |
09-17-2006, 09:10 PM | #12 |
well as for quality I think the brushless motors look pretty good. I have a mamba max 7700 brushless system and the motor looks remarkably close to the there 50 motor theirs http://www.bidproduct.com/part/Produ...w_MOTOR_2.html I think I will be buying a few motors soon |
10-03-2006, 06:21 PM | #13 |
I got my 4-channel AM receivers today, but only one of them works. They're sending another one free. The power taps aren't pinned, so if you use an RX pack, you'll have to plug into channel 4. Other than that, what can I say? It's a receiver, it receives. Even if they'd said tough luck it was half the price of a Traxxas receiver, for the pair of them, shipped. Think I'll order a few more. It's actually cheaper than waterproofing |
10-05-2006, 01:52 PM | #14 |
Newbie Join Date: Oct 2006 Location: Cincinnati
Dont forget you get what you pay for.
10-05-2006, 01:57 PM | #15 | |
10-25-2006, 01:26 PM | #16 |
I got a replacement for the dud receiver, so I ordered six more The S&H is a little heavy, but each receiver still ends up costing just over five bucks. |
10-25-2006, 09:43 PM | #17 | |
Pebble Pounder Join Date: May 2006 Location: Abington
they have one servo in there that has 3kg/cm which comes out to be almost 269oz/in of torque. and that's at 4.8 volts. that should be enough for crawling. http://www.bidproduct.com/part/Produ..._SERVOS_3.html | |
10-25-2006, 10:07 PM | #18 |
Ordered a couple receivers and servos. Time will tell! |
10-26-2006, 12:50 PM | #19 |
Pebble Pounder Join Date: Sep 2006 Location: Hardin
which servo should i go with for a 1:18 Nylint?
10-26-2006, 01:01 PM | #20 | |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
