09-20-2006, 08:28 AM | #1 |
| Somewhat newbie question
I have been in RC for years but this is my first time ever having to ask this here is the deal. I plan on running a emaxx tranny on one 65T integy lathe motor on my rig and only a single servo for steering and a second on for a winch. I have a LRP AI a traxxas tq3 and running a MG995 servo and a traxxas 2055 for the winch. will the bec have anough juice to run my servos or would i have to have an RX battery? or could i run a rx battery and have the bec thingie. If it doesnt work which cable do i disconnect from the ESC to run a RX pack. Thank you for any help |
09-20-2006, 08:38 AM | #2 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
If I remember correctly that ESC has a 1 amp or 1.5 amp BEC. That wouldn't be enough to use both servos at the same time. The red wire from the ESC that plugs into the receiver would have to be snipped to eliminate the BEC power when running a receiver pack. You run the risk of frying the ESC unless you disable BEC while running a rx pack. |
09-20-2006, 08:45 AM | #3 |
I have heard that onr 65t is weak on a maxx tranny. I'd say go for two 55t... This just came up not to long ago.....You don't have to cut the wire you can just pull it out at the end. So you can put it back if you need to reprogram the ESC.
09-20-2006, 12:29 PM | #4 | |
I also read that the tekin r2 has 6Volts and 5 amps BEC so how is that possible 6 volts is but there are no batteries that have 5 amp hours. Does it transform it to a higher amperage? | |
09-20-2006, 01:34 PM | #5 |
I think what R2J means is that a 65T is too slow and MAYBE would not have enough torque, depending on what kinda rig it was for. With two 55T motors, you essentially would double the torque of a single 55T and have more speed than the single 65T motor because a 55T motor is faster. It seems like you're getting turns confused. The lower the number of turns, the faster the motor, the higher the number of turns, the slower the motor and the more torque you get. |
09-20-2006, 06:13 PM | #6 | |
09-20-2006, 06:23 PM | #7 |
If you run a 65T and a 35T on the same spur, won't that cause problems? A 65T spins way slower than a 35T. One of the motors would overheat I'd think...
09-20-2006, 06:57 PM | #8 |
Both motors on the motorplate but pinion not touching the spur gear on one motor. only one runs at one time while the other just chills and is needed when i need more speed.
