Thread: BEC wire
Old 04-24-2013, 10:53 AM   #1
Default BEC wire
After searching a good bit, I see a lot about wiring a BEC but nothing on what to wire with. I am thinking that some 22g servo wire and connectors would be sufficient. Plus I can use it for some custom LED stuff. My only uncertainty with the connectors is compatibility. I have a Futaba 4pl on the way along with a Hitec servo. It seems like they are compatible but sometimes marketed differently. I am thinking of RC Dude because he has what I want plus a Hyperion charger I need. Does any of this sound good or compatible? My wraith kit is on the way and I am trying to order everything for the build.
Dfl4000 is offline   Reply With Quote
Old 04-24-2013, 11:36 AM   #2
Default Re: BEC wire
A BEC comes with its own wire...
a red and black wire for power to it...
and a servo type lead with a plug on it to plug it into your RX.........
roksloski is offline   Reply With Quote
Old 04-24-2013, 11:40 AM   #3
The 22 ga. servo wire and connectors work. I try to match the wire size to what is on the servo.
I use the Hitec connectors that don't have the tab. They fit fine into Futaba connectors and receivers.
k7zpj is offline   Reply With Quote
Old 04-24-2013, 12:36 PM   #4
Thanks guys. I understand the Bec comes with the wires, I just want to make things modular for easy assembly and disassembly. I have a feeling I will be in and out of this thing all the time. I can never leave well enough alone.
BEC wire - Similar Threads
Bec wire length? gtxr Electronics 5 05-04-2012 12:32 AM
How to wire a exceed rc bec idk Electronics 15 03-30-2012 12:02 PM
How do I wire a CC BEC into a LNC? Voteban Newbie General 8 05-05-2010 10:10 AM
Bec wire question eric113 Electronics 5 09-06-2009 07:27 PM
How to wire a CC BEC? fusebmx13 Axial AX-10 Scorpion 5 04-15-2009 04:29 PM
