09-22-2006, 09:17 AM | #1 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| xrs problems (i think)
When I turn to the left the servo starts doing is own thing, turning to the right is no problem,all this happens when it is on the ground with-in 3-5 seconds. If I hold it up in the air it takes 10 seconds or more before the left turn creates issues Changed the servo already same results... Used the throttle channel on reciever same results... Using a spectrum reciever and a 656 servo,2.2 truck,PTI axles, w/moabs on wild daggers and wideners Any thoughts before I go and replace the ESC or reciever. |
09-22-2006, 11:12 AM | #2 |
Rock Crawler Join Date: Apr 2004 Location: North GA
If you have an RX pack available, unplug the esc and use the rx pack to power the servo. That will tell you if it's the ESC or not.
09-22-2006, 11:13 AM | #3 | |
Quarry Creeper Join Date: Feb 2006 Location: In da 801 "AKA Tiny"
09-22-2006, 12:03 PM | #4 |
thanks I will try the rx pack. hate to add the extra wieght but if it works...
09-22-2006, 12:16 PM | #5 |
Well, you could also use a servo regulator. Novak makes one. It's tiny. It can be found on Tower for 20 bones.
09-23-2006, 03:09 PM | #6 |
Figured out the problem or at least solved it. When I put the receiver pack in place problem solved, I wasnt satified with running the rx pack so I decided to change my rx itself since I had just upgraded to a spectrum system. Changed with a spare spectrum----same results.. PUT THE TQ3 back in and all works well. SO.....................I believe that it is a compatability issue between the spectrum rx and the xrs esc
