05-10-2013, 10:51 AM | #1 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Using Futaba FHSS system?
Just found this...no antenna!! Pretty cool Futaba R204GF-E High Voltage 2.4GHz S-FHSS 4-Channel Micro Receiver [FUTL7604] | Radios & Accessories - A Main Hobbies |
05-10-2013, 12:35 PM | #2 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
| Re: Using Futaba FHSS system?
I have three of these. Two in scalers and one in my b4.2 buggy. They work great. Haven't had a problem with range yet. |
05-11-2013, 07:51 AM | #3 | |
| Re: Using Futaba FHSS system? Quote:
PS, I know the 4PL requires you to change/select the correct mode when using different RX's. | |
05-11-2013, 07:58 AM | #4 |
RCC Addict Join Date: May 2011 Location: Utah County
Make sure your tx isn't a FASST system. If you need cheap brass check hobby kings FrSky FASST rx's. Cheaper than that one Sent from my SCH-I535 using Tapatalk 2 |
05-11-2013, 08:49 AM | #5 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
I use these ones Futaba R2106GF 2.4GHz FHSS 6-Channel Micro Receiver [FUTL7605] | Radios & Accessories - A Main Hobbies and they work great!!! Have one in a scaler and my xr and haven't had ny range issues.
05-11-2013, 10:25 AM | #6 |
The 4PL is an FHSS system...not Fasst
05-11-2013, 10:46 AM | #7 |
This a thread about fhss receivers. Why are we even talking about fasst?
05-11-2013, 12:28 PM | #8 |
| Re: Using Futaba FHSS system? Wish I knew!! I KNOW the difference between FHSS and Fasst systems. I have both. I started this thread just to see if anyone were using this particular Rx. I thought it was cool just for the fact that it's antenna-less.
05-11-2013, 12:35 PM | #9 | |
Within FHSS, there are 2 differnt types, you have to select the correct one. Would not be the 1st time someone found a "great & cheap RX" only to find later it won't work with the TX. | |
05-11-2013, 01:10 PM | #10 | |
FutabaŽ FHSS & S-FHSS Rx/Tx Compatibility For the 4 PL it even has it broken down by S-FHSS normal and high modes. I have one of the R204GF-E receivers and it works with both modes with the 4PL. | |
05-11-2013, 01:16 PM | #11 |
| Re: Using Futaba FHSS system? |
05-11-2013, 01:31 PM | #12 | |
Check the specs... | |
05-11-2013, 01:39 PM | #13 | |||
Get off my butt.......how do I know the RX in question not was looking to be paired with a 3PM-x?????? Show me where the 1st post states the OP was using a 4PL......go ahead...show me....... Post 5 is the 1st time the TX was stated....... | |||
05-11-2013, 01:47 PM | #14 | |
It's beside the point but his sig states he is using a 4pl. | |
05-11-2013, 01:49 PM | #15 |
05-11-2013, 01:53 PM | #16 | |
I posted the link the compatibility chart so people could see what radios work with what radios and gave my personal experience with the receiver. Also I totally agree with your comments about having some kind of documentation about the receiver comparability before spending $$$$$ before you know it works. I guess I should if made my post simpler. I will try it again. Before buying any FSHH receiver for use with your Futaba radio check this chart. FutabaŽ FHSS & S-FHSS Rx/Tx Compatibility | |
05-11-2013, 03:23 PM | #17 | ||
Then again, I run 2 different radios, the OP may also but not list all of his. Shrug. I will yield, not worth pissing on further. As I already stated. Quote:
Thanks. I will assume the info is good for others, pissing is over, thus we can continue on as always. Hope all have a nice weekend of crawling. Don't forget, tomorrow is Mothers Day. While I may come off as a "Mother", I'm not a Mom, so remember yours. | ||
05-11-2013, 03:43 PM | #18 |
Rock Crawler Join Date: Nov 2011 Location: Omaha, Nebraska
I use this rx in my scaler with a 3pl works great no problems other than when i bought my first one and took my rig out i forgot to fill the hole in my radioshack project box where all the wires come out and i submerged the rig and it kept running the rest of the run but when i went to run it the next day the rx was ruined. but i have learned my lesson.
