05-13-2013, 06:30 PM | #1 |
Newbie Join Date: Mar 2013 Location: los angeles c
| brxl duel motor limit
Can the brxl handle duel 11t motors and if so on what voltage
05-13-2013, 06:34 PM | #2 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
| Re: brxl duel motor limit
Are you talking normal 11t motors or Crawlmaster 11t motors? The crawlmaster arms are a 5 segment arm, an 11t is really like a 20t or so. A brxl should handle it ok.....if normal 11t arms, that might be a bit much for it, but I would double check the specs.... Later EddieO |
05-13-2013, 10:07 PM | #3 |
duel 11t 5 slot pro custom motors so basically a crawlmaster. Holmes Hobbies LLC |
05-13-2013, 10:12 PM | #4 |
looks like the pro custom isnt available 11t so ill just get the crawl master in an 11t so this: Holmes Hobbies LLC |
05-13-2013, 11:06 PM | #5 |
Well, a 11t Pro custom with a 3 segment arm is a MUCH more powerful motor. People get confused by the turns between the 5 segment arms and the 3 segment arms. 5 segments are wound completely different, so typically they need half the winds to be around the same power as their 3 segment equal.... Sounds like you were given some bad info in regard to how they translate over. I know some people think because the crawlmasters are smoother in startup, you can use a lower wind....but that has nothing to do with it. You have to use a lower wind to get the power where you need it, regardless of smoothness.....just how they work. Later EddieO |
brxl duel motor limit - Similar Threads | ||||
rc4wd outcry duel motor esc? | smeesho | Electronics | 2 | 03-02-2013 08:45 PM |
AE 2 motor limit | bro_die | Electronics | 3 | 07-16-2011 02:36 AM |
novak rooster duel motor | smedo | Electronics | 1 | 11-20-2009 02:19 PM |
motor limit? | pmi_man | Newbie General | 3 | 04-27-2006 08:38 AM |
Motor limit | revoster | Newbie General | 2 | 04-15-2006 07:25 PM |
