09-24-2006, 04:37 PM | #1 |
| Mamba troubles
These Mambas always have a series of beeps when you plug the battery in and then when you turn the controller on. Mines not doing anything. I have full control of the steering,it's working fine but I have no response at all from the throttle. When I plug a fresh battery into the Mamba and turn it on,the lights blink a few times....pause....blink a couple more times and then go solid. When I push the throtle to go foward,the lights go out,push the throtle to go into reverse and the red light flashes. There is still no movement in either direction and steering works fine. I thought maybe the reciever was junk. I took the brand new reciever out of my brothers truck I built for him to try. I know it's fine cuz I've only run it once. I put it in mine and nothing changes. Put it back in my brothers truck and his still works fine. That tells mre the reciever in mine is still good???? It's doing the same thing with either the new reciever or the old one. Any ideas guys???? Thanks, Steve BTW,it's a Mamba Maxx,I'm running.... |
09-24-2006, 04:40 PM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Sounds like the trouble I was having at the Nationals. People were telling me it was the power switch, but it's been working fine since I got back.
09-24-2006, 04:40 PM | #3 |
I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
Sounds like your motor is unpluged.
09-24-2006, 04:44 PM | #4 | |
Do I need to drive it to Moab and come back to fix it That sounds odd I can try to put a new switch it in maybe,I just hate hacking into factory wires,just incase I need to return it for service or something. | |
09-24-2006, 04:45 PM | #5 | |
I've checked the motor wires a few times,they are definitly hooked up. | |
09-24-2006, 09:04 PM | #6 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
09-24-2006, 09:19 PM | #7 | |
I'm just using a regular ol' TQ3 with a modded switch for rear steer. I don't think that would be an issue,would it? I even tried switching crystals and tried my sons bone stock TQ3 and no change. | |
09-24-2006, 09:23 PM | #8 | |
everytime the esc is used with a different system it must be set up to that system | |
09-24-2006, 09:32 PM | #9 |
Like I said in the P.M. it's been working great for a while now,2 or 3 months. It's just all off a sudden done this. I went from 7 cells changed it to lipo settings,didn't like the lipo and ditched that and went back to 8 sub c cells. I tried the cut off at 4,5,6 volts as the cut off and it never will do anything.
09-24-2006, 09:34 PM | #10 | |
09-24-2006, 09:40 PM | #11 |
I've got 7 8 cell packs to choose from. They were all charged up last night. I tried several of them just to be sure but there was no change. The chargers I'm running are an Integy 16x4 for charging at the house. I've also got a Triton charger I can use but it's 12 volt only. I use both if we go to a get together cuz they'll both work on 12 volts. The Integy is nice if I don't wanna fool with gettin under the hood of the truck and were at home. |
09-24-2006, 09:42 PM | #12 | |
09-24-2006, 09:45 PM | #13 | |
Not that I'm aware of. I'm gonna try to download the newer version from Pheonix and try to reset everything. Maybe it's just that simple? | |
09-24-2006, 09:47 PM | #14 | |
09-24-2006, 10:37 PM | #15 | |
I tried downloading the newer version and tried updating my ESC. Nothing so far. I think I'm gonna go to bed now and fool with it tommorrow. I'm pretty tired and I'm probly overlooking something. After work maybe I'll stumble onto something.. | |
09-25-2006, 08:44 AM | #16 |
Sounds like when you flashed the setting the mamba "forgot" the radio settings. You will need to set up the ESC to the radio, just follow the instructions online or in your manual. I have heard with the tq3 you might have to set the throttle trim WAAAY off in one direction for it to work.
09-25-2006, 08:51 AM | #17 | |
09-25-2006, 04:50 PM | #18 | |
Could this be it? | |
09-25-2006, 04:55 PM | #19 |
You know what? My 2820 has done the same thing a few times. It wont even beep! I acts like a bad wind or something. Im gonna take mine apart and see what I find.
09-25-2006, 05:02 PM | #20 |
Well, that was fast!! The middle motor plug installed from the factory had a cold solder joint and was broken off. Hopefully your trouble is as easy to spot Raptorman.
