09-24-2006, 10:18 PM | #1 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
| BL setup info thread.
I thought it might be a good idea for each of us to post up our settings on each of your BL setups. Id like to see the name of the controller, the motor, batteries,and the setting you have made work for you best. include the vehicle weight and and type. controller motor batteries current settings vehicle type vehicle weight trans (If applicable) pinion/spur combo current issues if any. Last edited by rockwerks; 09-24-2006 at 10:28 PM. |
09-24-2006, 10:25 PM | #2 |
juggy 2.2, stealth tranny with 2.65 conversion, 12T/87T, mamba maxx, revolver total weight ready to run 5.5 lbs, 7 cell 2/3a 1200IB or 1400 IB settings Brake amount: 100% Reverse throttle A: 100% punch control: 0% drag brake: 90% start power: medium. motor timing: normal cutoff voltage: No Cutoff I have just downloaded the 2.19, have not run it since then. only issue I have is run time, the batteries will get one good or 2 good courses then the batteries depleat enough that on big climbs or binds it has a hard time starting out. I now will be running a fresh pack for each comp course. |
