Thread: needing some help
Old 08-12-2013, 08:33 AM   #1
Default needing some help
im having problems with my ecs and motor (540 senserd brush-less) i got it for my wraith but put it in my slash 4x4 and it did amazing it had extremely smooth excel. crawling around on rocks but lacked on top speed so i decided to put it in my wraith but trying to crawl with it well you cant when crawling on rocks the motor pulses. if anyone knows the anser please help
rider3r is offline   Reply With Quote
Old 08-12-2013, 10:11 AM   #2
Default Re: needing some help
Sounds like its cogging. Was it doing this in the slash? I would check wiring to the motor. The sensor wire and the 3 power leads. With a sensored motor A has to be connected to A, B to B etc... If you can I would try replacing the sensor wire. These are fragile and prone to failure. Be sure it is 100% engaged into both the motor and esc. It's this harness that relays exactly what position that the rotor inside the motor is in to the esc. What brand name is the motor and esc? and do they have the ability to run sensorless?
Quick Test is to unplug the sensor harness and see if the motor acts the same. if it does its most likely the harness or the actual sensors/sensor board.
hth
e
envious8420 is offline   Reply With Quote
needing some help - Similar Threads
needing some help newbiecrawler20 Large Scale Rigs 70 06-02-2014 05:55 PM
Needing help TRIGGER Redcat Crawlers 5 01-10-2011 10:01 PM
New Builder needing help lintonm HPI Wheely King 1 07-13-2010 10:28 AM
