08-12-2013, 08:33 AM | #1 |
Newbie Join Date: Jan 2012 Location: SPRINGVILLE
| needing some help
im having problems with my ecs and motor (540 senserd brush-less) i got it for my wraith but put it in my slash 4x4 and it did amazing it had extremely smooth excel. crawling around on rocks but lacked on top speed so i decided to put it in my wraith but trying to crawl with it well you cant when crawling on rocks the motor pulses. if anyone knows the anser please help
08-12-2013, 10:11 AM | #2 |
Quarry Creeper Join Date: Oct 2004 Location: Cow crap flats
| Re: needing some help
Sounds like its cogging. Was it doing this in the slash? I would check wiring to the motor. The sensor wire and the 3 power leads. With a sensored motor A has to be connected to A, B to B etc... If you can I would try replacing the sensor wire. These are fragile and prone to failure. Be sure it is 100% engaged into both the motor and esc. It's this harness that relays exactly what position that the rotor inside the motor is in to the esc. What brand name is the motor and esc? and do they have the ability to run sensorless? Quick Test is to unplug the sensor harness and see if the motor acts the same. if it does its most likely the harness or the actual sensors/sensor board. hth e |
needing some help - Similar Threads | ||||
needing some help | newbiecrawler20 | Large Scale Rigs | 70 | 06-02-2014 05:55 PM |
Needing help | TRIGGER | Redcat Crawlers | 5 | 01-10-2011 10:01 PM |
New Builder needing help | lintonm | HPI Wheely King | 1 | 07-13-2010 10:28 AM |
