09-27-2006, 07:53 PM | #1 |
Rock Crawler Join Date: Aug 2006 Location: Pinedale, WY
| RX Battery pack
I went out today and bought a 4AA Battery holder and i was wondering how would i wire it up to my Reciever?
09-27-2006, 07:57 PM | #2 | |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
2.wire positive to the red wire, negative to the black wire, and nothing to the white wire. 3. ???? 4. Plug it in the battery slot on your receiver - PROFIT!!!! | |
09-27-2006, 07:58 PM | #3 | |
09-27-2006, 08:41 PM | #4 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
are you trying to use the rx pack to run your servos and then have another pack that connects to your esc to run the motors? if so, you need to cut the red wire from the esc to the rx. also it would be better to use a 5 cell reciever pack for your servos
09-29-2006, 12:47 AM | #5 |
RCC Addict Join Date: Apr 2005 Location: Seattle
this also allow more power to the motor while full crank on the servo?
09-29-2006, 04:51 AM | #6 |
Pebble Pounder Join Date: Sep 2006 Location: SW Charlotte
i belive the motor takes priority over the servos, so it means the servos get full power when the motor is wide open....
09-29-2006, 08:16 AM | #7 |
Rock Crawler Join Date: Jan 2004 Location: Round Rock, TX
Or, don't cut the red wire, and just leave the the ESC's switch off. Either way, don't leave the external pack plugged in all the time unless you use a switch on that. |
09-29-2006, 09:17 AM | #8 |
Quarry Creeper Join Date: Sep 2005 Location: VARCOR
Holy's idea is good. Also instead of cutting the red wire on the ESC just pull it out of the plug and tape it off. This way if your servo batteries dye you can still use it. 5 cell is ok if you have rechargables. They pull 1.2 volt x 5cell = 6volt. 4 Regular AA are 1.5 x 4 = 6 volts.
10-01-2006, 03:29 PM | #9 |
Thanks!! it worked. im using AA's (not rechargeable) my turning speed and torque has improved awesomely!!! i put the red wire to the + side and black wire to the - and solder'd it up and BAM instant "profit" (unholy quote)
10-06-2006, 02:33 AM | #10 | |
10-06-2006, 04:26 AM | #11 |
You simply don't turn the esc's switch on.
10-06-2006, 07:57 AM | #12 |
I don't get it, the ESC can operate with the switch in the off position?
10-06-2006, 08:27 AM | #13 |
I know for a fact that a Novak Super Rooster does. It gets its power from the receiver pack, just like the servos.
10-06-2006, 06:23 PM | #14 |
Hmmm, well I am running a Rooster, so I'll have to give this a try.
10-21-2006, 12:15 PM | #15 |
Quarry Creeper Join Date: Jul 2006 Location: I didn't build that course.
so if i have a pack plugged into the esc and another pack plugged into the reciever with a switch on each and i leave the power switch for the esc off and the switch for the reciever pack on will it still use the power from the pack plugged into the esc ?
10-21-2006, 12:17 PM | #16 |
Yes, but if you turn the ESC switch on you run the risk of frying the ESC.
10-21-2006, 12:19 PM | #17 |
cool i didnt think the esc would draw poer from the pack wires to it with the switch off dont that break the connection ?
10-21-2006, 12:20 PM | #18 |
The way it was described to me was to plug a pack into the esc, remove the black wire from the servo plug from the esc and plug it into the receiver. Then plug your receiver pack into the receiver as normal. The ESC will take it's power from the pack it's directly connected to, and the servo will be powered by the receiver pack.
10-21-2006, 12:21 PM | #19 |
It just breaks the connection from the battery power.
