Thread: Is my servo going bad
Old 06-16-2013, 10:07 PM   #1
KMS
KMS's Avatar
Default Is my servo going bad
I run a Tekin fxr with castle bec 3s lipo Hitec 7955 servo, When first installed [ last year] There was nothing that stopped the steering ,It was awsum ,But now its like not having a bec any more ,,,Looking for a little help please ,,hour of reading threads and still hav'nt figed it out ,,, oh last up grade was a Hacked FS-GT3C ,,did I miss something there ...Robert
KMS is offline   Reply With Quote
Old 06-16-2013, 10:23 PM   #2
Default Re: Is my servo going bad
Everything is going to be all right now.
riscenvan is offline   Reply With Quote
Old 06-17-2013, 12:57 AM   #3
Location: Turn the mayflower around.. it will never work
Robert, what do you mean by " it seems like I'm not running bec" ? Also how is your bec installed? And what voltage are you running? Also if you turn the servo horn/ arm how does it feel? Feel like a new servo or does it not make winding noises like a new servo? Have you taken off the back and looked for any heat spots on circuit board?
You may have stalled out the servo too many times and fried the motor and/ or fried the amplifier (its what hitec refers to it as) right in the middle of the board.
Sounds to me like the motor is tore up. I just sent two brand new 7954s back, one for motor and other for motor and amplifier. Both of mine were running 7.33 and 7.35 volts and should have been safe. When I got them back I turned on the overload protection and set to 10%. We will see if that works.
JokersWild is offline   Reply With Quote
Old 06-17-2013, 07:50 AM   #4
KMS
KMS's Avatar
The servo still works ,But it dont have the power it had when I first installed the bec ,I will pull the servo and check the board ..bec set at factory setting ,havent messed with it ,,I think 6volts,, Thank you for your help Robert
Old 06-17-2013, 11:23 AM   #5
No problem. Like I said it may just be the motor over heated and is going bad internally. You should be able to tell by turning servo horn. Hitec has great warranty service. 2 years from purchace, get on their site..... Print out paper for return, fill out and put in copy of purchace and mail off. About 2 week turn around.
Old 06-17-2013, 10:50 PM   #6
KMS
KMS's Avatar
Found the problem ,every thing is ok ,,moved panhard mount and it helped a bunch ,,,Thankyou JokesWid ,,for your help,,,Robert
Is my servo going bad - Similar Threads
It's not a bad servo NEW YORK BOY Vaterra Twin Hammers 5 02-12-2013 10:44 PM
bad servo brushlessnut Losi Micro-Rock Crawler 11 01-12-2010 04:10 PM
Servo Gone Bad? cmac888v2 Electronics 0 04-28-2008 12:34 AM
