06-17-2013, 08:05 PM | #1 |
Quarry Creeper Join Date: Sep 2010 Location: Gilbert, Az
| wiring crawler double check
all, i am trying to finish building my first crawler (bully) i wanted to get verification from the elect. gurus on here to make sure all is connected correctly so... 1) i have the integy 35 & 45 motors connected to the punk dig with the two wires (red-blk)from the dig connected to the red-blk (w/ wht-but loose) wires of the CC sidewinder s2? 2) the other dig wires are connected to the "aux" in my sr300 reciever (DX3E) 3) the steer. servo connected to the steer. in the reciever 4) the ESC is plugged into the throttle in the reciever 5) the other ESC wires are going to be connected to the 1300(2s) lipo so before i plug in the batt i want to make sure that the wires are all connected correctly thanks for the responses!!! rc dreemer |
06-24-2013, 09:47 AM | #2 |
| Re: wiring crawler double check
well i tried to see if the wiring worked & i got nothin' i tried to "program" the esc & it is not working i have know clue onwhat to do now any help/ideas would be very much appreciated ....please |
06-25-2013, 01:50 AM | #3 |
Rock Stacker Join Date: Dec 2008 Location: Queensland Australia
What esc have you got? does it power up at all; do you have steering? A basic question Is the receiver bound to the transmitter?
06-25-2013, 08:21 AM | #4 |
wheely, i do have power, but the ESC (CC SV2 sidewinder) just shows a yellow blinking light. I tried to follow the initial start up proceedure, but i must not have done something correctly. i have no movement & no steering i am not good with "wiring" things (rc related) hence my original question. i have no idea where to begin &/or what to try??? i have read the truobleshooting in the directions but it does not help any..... i get no lights on the punk dig as well... ?? thanks for the reply..... |
06-25-2013, 09:22 AM | #5 |
Quarry Creeper Join Date: Oct 2010 Location: Land of the Cactus
Your are sure your tx/rx are bound together? Even with the esc not calibrated, you should atleast be able to steer right off the bat if the rx/tx are bound. Make sure they are bound together first. Have you used this tx/rx on another rc before using it for your crawler?
06-25-2013, 03:34 PM | #6 |
sheepdawg, i am pretty sure they are bound... i have used them in my scx10. the remote & reciever seemed to be in working order when i moved the reciever to the crawlera few days ago.... thanks!! |
06-27-2013, 04:30 AM | #7 |
Newbie Join Date: Jun 2013 Location: Internet
Good to know that informative news about wiring crawler double check. "rc dreemer" You did right and you are at right stage. Share with us your obtained goals after this experiment. NTEP Scales Last edited by Edward Ronald; 06-28-2013 at 10:51 PM. |
06-28-2013, 09:52 PM | #8 |
??? anyways, a LHS indicated that the dig is bad soooo i guess i need a dig to get it all running. the good news is that i appearently have everything hooked up correctly |
06-29-2013, 09:18 AM | #9 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
You still would have steering....... And esc would power up. The dig is between esc and motor so every thing before that should work fine if dig is bad.
07-01-2013, 08:39 AM | #10 |
joker, yea i had steering & throttle once i recharged the batt. & plugged it back in. the dig i guess was not sending the signal(s) to the motors...... anyways i am now on the lookout for a dig unit...... preferably one that works! thanks! |
wiring crawler double check - Similar Threads | ||||
Check out these's Double Pully | rockn2 | Chit Chat | 5 | 06-18-2012 05:30 PM |
Double Check | hibbs | Electronics | 3 | 04-13-2011 06:59 PM |
Double check me please!!! | Veilside159 | Newbie General | 4 | 11-30-2009 09:12 PM |
ALWAYS double check rear end parts! (1:1) | Going Up! | Chit Chat | 18 | 05-05-2007 01:42 PM |
