Thread: motor turn to kv conversion chart
Old 06-25-2013, 01:03 PM   #1
Default motor turn to kv conversion chart
I found this info from the following site, that maybe helpful to some
Brushless Motors
it help me out alot
bikeboy is offline   Reply With Quote
Old 06-25-2013, 10:36 PM   #2
Looks like it will work for general 1/10 motors. I dont think itll work for 1/8 motors since my 2400 watt 2560KV motor is not close to anything on there.
Sent from my Transformer using Tapatalk 2
Deerhurst is offline   Reply With Quote
Old 06-25-2013, 10:55 PM   #3
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Default Re: motor turn to kv conversion chart
Besides the use of "censored" instead of sensored, and his broad assumption that all 540 motors have the same KV for a wind, its a good effort. At least it gives people a ballpark to start with, but don't read too deeply into it or expect motor speeds to follow the chart closely. Even the method of determining KV isn't standardized in the business, so one company may rate it at zero amps and high timing with an AC voltmeter and another is rated under no load and low timing with a peak to peak measurement.
Its a very loose system, quite maddening for a person trying to collect an accurate data set.
JohnRobHolmes is offline   Reply With Quote
Old 06-27-2013, 04:35 AM   #4
Thanks for sharing motor turn to kv conversion chart informative guideline. Its really useful and acknowledging post.
NTEP Scales
Edward Ronald is offline   Reply With Quote
motor turn to kv conversion chart - Similar Threads
motor turn to brushless rpm/v conversion? STANG KILLA SS Chit Chat 5 02-09-2015 04:13 PM
Higher Turn Motor Vs Lower Turn Motor ? ReignMan Newbie General 10 11-15-2009 10:40 PM
higher turn motor or lower turn motor......... bob1961 Newbie General 6 03-18-2008 09:16 PM
