06-26-2013, 04:04 PM | #1 |
Quarry Creeper Join Date: May 2012 Location: vernon bc
| kyosho syncro kt-201 issue
hi guys, I have a kt-201 trans/receiver and im just wondering if anyone else is running these? im having what seems to be a range issue with mine. I cant get more then 35 feet away from it or it will loose all function. my question is do I really need to have the antenna sticking up outside of the waterproof box? the stock axial rtr radio set has great range with antenna inside the box so I don't understand this. any help would be great.
06-27-2013, 12:15 PM | #2 |
| Re: kyosho syncro kt-201 issue
well I just read the manual online about this radio, I cant find mine. it says this radio was designed with a surface range of 100m ? I sure wish I knew this before buying it. just wanted to let others know in case they were thinking of this radio.
07-02-2013, 01:53 AM | #3 |
Newbie Join Date: May 2013 Location: Sabah
I'm using it too, mine has good range I think more than 35m, but after a month using it, problem came out. When u turn right 100% my car goes forward and if u turn 100% left goes reverse. I try calibrate it again but same result. I think I will need new radio set that much more reliable.
07-30-2013, 08:42 AM | #4 |
Quarry Creeper Join Date: Apr 2013 Location: perkasie
i use this same radio in 3 different cars (same transmitter 3 rx).....i love it and ive had no range issues..... i would double check the ant wire on the rx... i know the 2.4ghz radios are finicky about that.....mine is coiled up and sealed in a rx box and this thing has a range further than 100m
kyosho syncro kt-201 issue - Similar Threads | ||||
Volkswagen T3 syncro single cab | stef91 | 1.9 Scale Rigs | 28 | 07-20-2012 02:19 AM |
Kyosho Syncro KT-201 good for using dig? | Olle P | Team Losi Comp Crawler | 8 | 05-16-2012 11:06 AM |
Project VW Vanagon Syncro-The epic... | caprinut | 1.9 Scale Rigs | 8 | 05-19-2008 06:52 PM |
