Thread: Does this mean my motor is shot?
Old 07-09-2013, 12:30 PM   #1
Default Does this mean my motor is shot?
well I was using this 550 size motor from my MT in my wraith while I getting a proper 4wd motor, it had already 3 packs on the wraith and this last weekend after 5 minutes of running the car started to make a clack clack soung but pretty loud.
I stopped the car and dismanteled everything to check the tranny gears and they were good, same on my MIP shafts, diff gears good, so, nothing seem wrong, installed the motor on the tranny out from the car and rotated the shafts.. same sound, but tranny gears were smooth when I check them 5 minutes ago.. keep rotating the spur and same sound, I have no other option to open the motor and check it.
this is what i found
seem bit dirty LOL..
Im still a newb on RC and even more on BL power, but all that crap dont look too normal right? pieces or slices from I dont know where and a lot of oily ashes
time for a new motor
Steelfish is offline   Reply With Quote
Old 07-09-2013, 12:44 PM   #2
Default Re: Does this mean my motor is shot?
Specs on the motor? Gearing? 2s or 3s?
Later EddieO
EddieO is offline   Reply With Quote
Old 07-09-2013, 01:04 PM   #3
motor is a tacon 2726kv 550 size
when it was installed in my Ruckus MT (5lb truck)
battery used 3S LIFE 4500mah 30c turnigy 20 packs
and before that 7-cell nimh and 8-cell nimh 40 packs
gearing 56t / 18t
on the wraith i was using 56/15 gearing and only 3S life batts
specs
No of cells (lipo) 4
max efficiency (%) 85%-89%
max efficiency current 68
Turns (for cars)Poles 9T/2POLES
Max Voltage 16.8
Old 07-09-2013, 01:11 PM   #4
Overgeared....a 9t in a wraith is a bit overkill.
Later EddieO
Old 07-09-2013, 01:46 PM   #5
so with this motor what was the max gearing ratio ?
motor was never hot, average temps were always on 110f max on the temp gun..
if I want speed on a wraith what motor do you recommend? other than pro4 that everybody wants but its too pricey for me now.
Does this mean my motor is shot? - Similar Threads
long shot...ID this motor? brianw Electronics 9 08-21-2012 02:39 PM
Is my BL motor shot? Maxx_Savage Electronics 3 05-09-2012 02:55 PM
my shot at a tj.. mcreil41 1.9 Scale Rigs 17 01-24-2010 08:47 PM
Shot RodyRazorBackc5 Chit Chat 0 10-18-2006 08:27 PM
