07-10-2013, 01:10 AM | #1 |
Rock Crawler Join Date: Apr 2011 Location: British Columbia
| mamba max pro question
I just installed a mamba Max pro and a tekin red line 21.5 turn sensored motor and when I drive it , it seems like reverse is really slow, I have read through the manual but nothing useful
07-10-2013, 01:27 AM | #2 |
Quarry Creeper Join Date: May 2013 Location: on top of the rocks
| Re: mamba max pro question
Check your transmitter reverse end points,also you can program the esc for the amount of reverse you want.
07-10-2013, 01:33 AM | #3 |
I did the transmitter procedure, so I just need to up my amount of reverse?
07-10-2013, 02:24 AM | #4 |
Yes. The default reverse speed is 50% IIRC.
07-10-2013, 05:12 AM | #5 |
Quarry Creeper Join Date: Jan 2013 Location: LP, LA
Had the same thing recently on my first install/setup with a MMP. Had to program the reverse to 100%. Nice and easy if you follow the instructions and can hear well. The esc beeps at a low volume. Or maybe it is my loss of high freq sensitivity from years of working on and around turbine engine helicopters.
07-10-2013, 07:11 AM | #6 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Or plug it into castle link.
07-10-2013, 07:43 PM | #7 |
Newbie Join Date: Mar 2012 Location: Buffalo
I am having similar issues with a MMP... Its slow goin forward and fast in reverse tho. Forward and reverse values are both set at 100% Remote throttle rate is set at 100% as well... When i change rotation via castle link and reverse throttle channel of remote its still the same, slow forward and fast reverse. Any ideas???
07-10-2013, 07:49 PM | #8 |
Quarry Creeper Join Date: Nov 2011 Location: Vacaville
Sounds like mechanical timing in the motor.
07-10-2013, 08:00 PM | #9 |
Its a Novak Ballistic 13.5 turn sensored motor, guess i could've added that info!!! I have the "cheat" timing turned off.
07-11-2013, 12:17 AM | #10 |
The Ballistic has a 15 degrees timing built in. If it needs to "reverse" for the truck to move forward then that might be your problem. My motor also has 15 degrees mechanical timing, but I didn't notice that much of a speed difference when I had it running "backwards". Current consumption became a major concern though, as it pulls much more with negative timing. |
07-11-2013, 08:48 PM | #11 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
It could just be a soldering point on your motor, a 21.5t? That's a really slow motor, but that's my opinion, it could be an adjustment on your mamba max pro, if not call a tech., that could also be like a timing adjustment or even a setting witch the reverse is set higher than forward, idk if that would help but hope it does, - axial 4x4 crawler
07-11-2013, 10:55 PM | #12 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
open up your endpoints and then recalibrate the esc.
07-13-2013, 11:00 AM | #13 |
Plugged it into castle link and got it were I want, thanks folks |
mamba max pro question - Similar Threads | ||||
novak 7.5r with mamba max pro question. | obebaldone1 | Electronics | 2 | 11-19-2010 08:02 PM |
mamba max pro question | Boids | Electronics | 13 | 04-30-2010 07:48 AM |
Mamba Max Pro question | wrightcs77 | Electronics | 4 | 01-23-2010 10:00 AM |
