10-02-2006, 08:43 PM | #1 |
Quarry Creeper Join Date: Apr 2006 Location: sacramento
| winch.... help?
hey guys i just finished my servo winch on my truck... The winch is a crappy hitec hs 911 servo for now, but anyway it is wired to a 3way toggle switch that has a 9 volt batery pack soldered to it also so the servo, and the battery are soldered to the 3way switch. The battery started to get hot so i put in a ground wire and sqrewed it to some metal on my truck. But the battery still gets hot even with a ground wire...........any ideas? |
10-02-2006, 10:39 PM | #2 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Without seeing how you have things wired... Excessive heat at the 9V is a result of a high amp draw. Sounds like you've created a short somewhere in your wiring that is dead shorting + and - on the 9V. The ground wire thing concerns me. This isn't a 1:1 car that uses a common ground to the chassis. |
10-03-2006, 09:14 AM | #3 |
I joined the Band! Join Date: Aug 2005 Location: Cincinnati
wow that sounds like some HILLBILLY engineering with the ground....you increase your chances of a short and interference by "grounding" out the battery................ search for bare wire or stop picking your entire truck up with the servo
