09-09-2013, 09:00 PM | #1 |
Rock Stacker Join Date: May 2008 Location: Des Moines
| need help :Sidewinder micro repair
Hey Guys, does anyone have a guide or can give direction for repairing a sidewinder micro smash gone wrong? After the smash, one of my micros started to show some messed up behavior, on battery plug-in it would run the motor full throttle and the battery would start to smoke...yeah, i know. anyhow, after some research, it will fry a battery without a motor connected, but only when not plugged in to the receiver. if it isn't plugged into the receiver, it does nothing unusual, just sits there blinking red (waiting for a signal?). also, it doesn't matter if the transmitter is on or not. let the yelling and finger pointing begin!!!! any help is appreciated, i cant seem to find anything -Fred |
09-09-2013, 10:41 PM | #2 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Re: need help :Sidewinder micro repair
Just de-smash it and throw the offending ESC into the bin...... Seriously, desmashed it and redo the power wires on the offending ESC, it must have shorted somewhere... Was the esc new or working before the smash? |
09-10-2013, 05:56 AM | #3 |
Its been pulled and rewired a couple odf times. No luck. It was working correctly before i messed with it. A few weeks old. Maybe 30 packs on it. Sent from my LG-US730 using Tapatalk 2 |
09-10-2013, 06:07 AM | #4 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
Sounds like you got the board too hot soldering the shortened wires and melted one of the connections. If you can find were it's melted you may be able to salvage it.
09-10-2013, 07:27 PM | #5 |
Maybe take a close up pic on both sides of the ESC....
09-10-2013, 08:19 PM | #6 |
anything that might help! let me know if something isn't clear |
09-10-2013, 09:00 PM | #7 |
On the second picture, there seems to be something missing at the connect point of the Rx wire. I don't have one to compare (they are all warped up). Check with the working one you have. Also the Rx connection and the on-off swich point seems to have a bit of solder connecting them, clear them. Can you also clear the solder between the 3 IC chips? Otherwise It looks ok to me. |
09-10-2013, 09:16 PM | #8 |
hey, thanks for the insight, Colgout, there is supposed to be a SMT cap (i think) across the signal and ground wires . that was a recent change, it was on there when things went wrong. When you say clear the solder between the ICs, i'm not sure i know where you are talking about. can you explain further? thanks man Also: i tried clearing all the solder joints and resoldering today, I also connected a single lithium ion battery with circuit protection. once again, when not connected to the receiver, it sits there just fine and blinks red, seems ok to me. as soon as i plug it into the receiver, it trips the protection circuit and shuts off. doesnt matter what state the receiver is in, powered, unpowered. argh Last edited by freddyg; 09-10-2013 at 09:22 PM. Reason: added details |
09-10-2013, 11:03 PM | #9 |
I meant where the Positive wire attach to. Yeah I notice my new MSW has a cap near the rx line, my older one (about 1 year old) one does not (from memory). Since your problem is only when connected to RX, can you use a multimeter to check if there is any shortage between the 3 rx wire? Use the working one as sample too see if the resistance between the 3 points are similar between the 2. Does it do the same if you only connect the signal wire to the Rx? Do you have another Rx to try? |
09-11-2013, 09:41 AM | #10 |
I will try some measurement comparisons tonight. I have tried another receiver, same behavior. thanks!
09-11-2013, 05:18 PM | #11 |
well, i dont know whats up, when i plug it into a receiver it gives me 3 quick flashes, all LED's then nothing and overheat... ugh looks like i'm sending it in
09-11-2013, 07:14 PM | #12 |
I think you better...(sending in). Sorry can't help. |
09-11-2013, 07:19 PM | #13 |
Who did the smash?
09-11-2013, 07:22 PM | #14 |
I wanna be Dave Join Date: Aug 2007 Location: *
A surface mount component is missing/broken here (red box): |
09-11-2013, 07:50 PM | #15 |
I did the smash. Yeah. happen to know the value of that cap? (I think its a cap) thought it would just be a filter/noise cap on the output But it may be more important. Sent from my LG-US730 using Tapatalk 2 |
need help :Sidewinder micro repair - Similar Threads | ||||
sidewinder with a cc bec,works great but Can I swap it out for a Micro sidewinder? | username | Electronics | 3 | 04-04-2009 10:11 PM |
