09-22-2013, 07:55 AM | #1 |
Quarry Creeper Join Date: Nov 2005 Location: Western, NC
| Holmes Hobbies Motor / ESC Combo Advice
Now that I've decided to stay brushed, I need a little help deciding which Holmes combo to buy for a Wraith. I've tried searching, and posted in the motor / esc section for the wraith, as well as looked on their site but no clear cut answers on any. I'll be installing the RC4WD AX2 2 speed trans at the same time. I want really good low gear crawl capability, with enough speed in high gear for it to still be fun when the terrain opens up. So, what combo and what wind on the motor? They have so many combos (torquemaster, crawlmaster, etc) on the site, with no real indication as to the difference between them that I have no idea what I need with the 2 speed. I sent them an email, and I'm sure they'll get back to me once the work week starts, but I figured someone here has to be running this combo already and has some feedback to offer.
09-22-2013, 09:24 AM | #2 |
| Re: Holmes Hobbies Motor / ESC Combo Advice
Talk to John and tell him your set up. Car, weight, intentions, ect and he'll give you what you need.
09-22-2013, 03:51 PM | #3 |
Pebble Pounder Join Date: Jan 2013 Location: Quebec, Qc, Canada
| Re: Holmes Hobbies Motor / ESC Combo Advice |
09-22-2013, 04:05 PM | #4 |
He does what he can. He is a busy man. Have you tried sending him a pm on here?
09-22-2013, 04:22 PM | #5 |
Thanks crawler nut, his profile doesn't allow PM's, so I used the email option. I'm just anxious to get it ordered is all, I know the stock motor is garbage and won't last long. I have another motor I can throw in short term if need be though.
09-23-2013, 09:48 AM | #6 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
Although not exactly your question, but I run a Team Brood Chaos 25T motor after EddieO recommendation. I matched it with a HH BR-XL and also a RC4WD 2speed tranny, this combo has been good for what you want it to do. Good crawling and still have a bit of top speed. I would say if you want to stay with HH (which is also great motor), try the Crawlmaster 13T, it should be awesome. It will be smoother than the Chaos, being a CM is a 5 segment arm vs Chaos 3 segment. If you want more torque, get a torque master pro 27T with big wire, high fill and strong magnet, that should do the trick. Or one of those new Puller, but I don't know much about them, never run it before. |
09-23-2013, 10:37 AM | #7 | |
| Re: Holmes Hobbies Motor / ESC Combo Advice Quote:
09-23-2013, 10:44 AM | #8 |
| Re: Holmes Hobbies Motor / ESC Combo Advice Actually if you re gear it to 13-15/87 in 48p or 10-12/56 in 32p the stock motor will last quite a while. He might have a contact # on his website.
09-23-2013, 11:40 AM | #9 | |
Another option is 3 segments armature with skewed stack, this will improve low speed control on a 3 segments arm. | |
09-23-2013, 03:35 PM | #10 | ||
Heard back from John today, he recommended the 35t torquemaster pro combo for my application, so I'm going to order that for now, and pick up that 13t down the road to try out also. Last edited by hpiguy; 09-23-2013 at 03:42 PM. | ||
09-23-2013, 07:09 PM | #11 |
If you want to (I did that), you can just order the 13T 5 seg armature later down the line and just swap out the 3 seg one, put in the new brushes and you are gold, the standard torque master and crawl master has the same can magnet and endbell, just the sticker different.
09-23-2013, 09:25 PM | #12 |
Good to know, thanks!
Holmes Hobbies Motor / ESC Combo Advice - Similar Threads | ||||
Needing expert advice on ESC/Motor combo | NiteRyder1976 | Axial SCX-10 | 13 | 05-27-2011 08:42 PM |
Holmes Motor/ESC/Lipo Combo | SgtDoogie | Electronics | 4 | 05-08-2009 01:17 PM |
