Thread: Smoldering Receiver.
Old 10-13-2006, 12:10 PM   #1
Landy mad
wallaz's Avatar
Default Smoldering Receiver.
I have been running my TLT on 9.6V through a TR2.
I have a seperate receiver battery connected after frying the BEC a number of months ago.
I had thought I would alter my main battery pack and add a tapping after 5 cells to eliminate the extra receiver battery.
My problem is that when I connect the battery pack to both the receiver and the ESC the reciver starts to smolder/smoke. It has also started to melt the insulation around the wires from the ESC to the reciver.
If I only connect to the battery to the receiver, no smoking
If I connect to the ESC only and add a seperate reciver pack, again all is fine.
Should I add a voltage regulator instead of tapping off?
Receiver is a Futaba R136F FM system.
Any help is much appreciated
wallaz is offline   Reply With Quote
Old 10-13-2006, 12:14 PM   #2
I'm a stupid C U N T!
he had the same problem Smokin' Mamba BEC?
all your answers are in here
slobin3d is offline   Reply With Quote
Old 10-13-2006, 12:32 PM   #3
Landy mad
wallaz's Avatar
Many thanks for that slobin3d.
I'll have to have a couple of reads through it but I think i've got the jist of it.
