Thread: digital pirhana charger survey
Old 10-13-2006, 09:27 PM   #1
BOUNDRYBASHER's Avatar
Default digital pirhana charger survey
i have a digi pirahana charger and a couple newer 1500mah nicad batts and am getting about 1000to 1100 mah after a 1C charge and am wondering if these are good numbers or not. I run the rig until noticeably difference in performance and the let the batts cool a little before charging as per common practice(i belive). when i got the new batts i did the common 14-16 1/10c rule but still noticing differences in run times between the two even after a couple discharge recharge cycles. just wondering what others are getting for mah delivered rates on there good packs.
p.s. have tried recommened 6mv/c and then 8mv/c setting and found a little more mah with the 8mv setting but just interested in others findings.thx
BOUNDRYBASHER is offline   Reply With Quote
