10-19-2013, 01:36 AM | #1 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Micro Sidewinder won't arm
I have a msw and when plugged in it beeps the first sequence but not the last bit. The green and yellow light was flashing, I have steering, but the motor won't turn and the light does not change (flashing green and yellow) with throttle setting. Can't go into calibration mode too. Plugged in Castle link and it works in program mode. Anyone know what's going on? Its a used one that come with no wire, I soldered all the wires back (minus the switch). |
10-19-2013, 01:57 AM | #2 |
Quarry Creeper Join Date: Nov 2005 Location: Western, NC
| Re: Micro Sidewinder won't arm
Have you checked to make sure your throttle trim is zeroed? Throttle EPA's at 100 both ways? And have you tried reversing the throttle channel?
10-19-2013, 08:38 AM | #3 |
Pebble Pounder Join Date: Sep 2010 Location: Lava Lands
I just had that happen on my sidewinder sv2. It would read 3cells, but not give the arming sequence. Try increasing your dead-band and re calibrate to your controller. Mine didn't seem to re calibrate and just beeped alot but it arms quick now.
10-19-2013, 10:37 AM | #4 |
Check the ESC LVC setting and make sure the pack is charged.... Castle Creations | FAQ: 1/10th Scale Products |
10-20-2013, 01:14 AM | #5 |
Pebble Pounder Join Date: Aug 2011 Location: NSW, Australia
Like Charlie said, yellow and Green flashing is the light sequence for LVC. Check you settings, maybe re-set the ESC to default settings and re program it.
10-20-2013, 07:56 AM | #6 |
Shortly after I posted, I read the Castle site and learned that the green and yellow light meant LVC activated, I then made sure the battery was fully charged but same thing happened. However after reading the reply, I reset the ESC and reprogrammed it and set the deadband to 1.125ms (large) and it works fine now.... I then tried to set the deadband back to the default 1.000ms and it does not arm (same green and yellow lights flashing). I set it back to 1.125ms and its ok now... It bugger me, because the other 3 MSW i have are at 1.000ms and works fine. Anyway this one works now and thank you guys. Last edited by Colgout; 10-20-2013 at 08:02 AM. |
10-20-2013, 08:37 AM | #7 |
Newbie Join Date: Jan 2013 Location: Australia
You might try a small amount of throttle trim and you might be able to reduce the deadband, it might not quite be seeing center. Is it the same transmitter your running the other micros on? |
10-20-2013, 09:20 AM | #8 |
yeap all msw run off a 4pl. it's ok as long as it works. just wonder why this msw need a wider deadband but no biggie.
Micro Sidewinder won't arm - Similar Threads | ||||
sidewinder with a cc bec,works great but Can I swap it out for a Micro sidewinder? | username | Electronics | 3 | 04-04-2009 10:11 PM |
