10-20-2013, 01:09 PM | #1 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| strange electrical gremlin. help!
So I have a 6x6 ( jebster's 6x6 ) that acts up. After about 10 minutes of running he steering servos go haywire. They start randomly swinging right and left, not responding to command. Throttle still responds normally. Not sure what to make of it so I'm looking for suggestions. Here is all the equipment involved. The rig has lights and a servo winch but this happens when neither of those are running. - Novak Goat 3s w/ 18.5 novak Crawler brushless motor - 3 solar servos for steering - Castle pro bec powering front axle servos; separate CC bec for rear axle - 4000mah 2s lipo (25c I believe) - airtronics mt-4 tx and 461 4ch rx Bec's are tapped off direct from the battery at the connection point to the esc. Esc lead carries the power to the rx. I've pulled the battery when this happens and it still has plenty of juice. If it was a draw issue I would have thought it would occur all the time, not after running for awhile. Could he bec's get hot and have problems? Since the throttle seems fine it doesn't to be an issue with the esc or rx getting enough juice. I'm open to all inputs on how to diagnois this. A little frustrating to say the least. |
10-20-2013, 01:39 PM | #2 |
Rock Crawler Join Date: May 2011 Location: Cali/Korea
Using the bec have u removed the main esc red power wire? also are ur servos warm at all? Something has to be heating up after that run time and then causing the issues. Thanks, ORK |
10-20-2013, 03:52 PM | #3 |
| Re: strange electrical gremlin. help!
Which hole on the servo horn are you using? They could be overdrawing and heating up if the leverage is too great from the outermost holes.
10-20-2013, 04:23 PM | #4 |
The bec's are direct to the servos, not through the rx so the esc powers the rx. I was thinking heat might be an issue. I'll have to feel a few parts next run. Just odd that all 3 servos act up when there are two separate circuits. As far as second arms go they are 1" long and I'm using the outer hole. |
10-20-2013, 05:41 PM | #5 |
Sounds like you have a decent set-up. Does the issue show up with any battery pack? Do you have a ground from the servo/BEC connection back to the RX? (Spektrum needs the grounds, other set-ups are finicky on if they need it). |
10-20-2013, 06:54 PM | #6 | |
| Re: strange electrical gremlin. help! Quote:
I only have the signal line running back from the servos to the rx. They do get jumpy if I switch off the esc since they still have power but otherwise they work fine until the mystery issue comes up. I did think of another experiment. I have the system set up to run front only / rear only / crab / opposing for the axles. Maybe I'll run just front then just rear to see if I can isolate the source. Keep the ideas coming guys. I hope I can get this solved. | |
10-22-2013, 04:43 PM | #7 |
The plot thickens. Took the cab off so I could test temps and ran it hard for 20 minutes today. No issues. The hottest and component of the system got was the motor and it only reached 98 degs. Battery, servos, esc, becs were all cool to the touch. I'm stumped as to what has caused the issue. From today's test heat doesn't seem to be a factor. Even with the cab on I'm sure there is enough cooling air getting in. Could it be some kind of interference? My kids were running their rigs the other day. Both are using traxxas 2.4ghz tq systems. |
10-22-2013, 05:14 PM | #8 | |
Thanks, ORK | |
10-22-2013, 05:23 PM | #9 | |
I do agree it seems to be associated with the rx but I have to keep working this. | |
10-22-2013, 07:30 PM | #10 |
Have the kids run their Traxxas radios again and see if the issue comes back. Also check your TX batteries. PS, do all the servos get twitchy or just 1 or 2? Do any share a RX channel? If so, are they the only ones that twitch? Just wondering if a single servo is creating an issue with the others (through a shared RX channel). |
10-23-2013, 04:21 AM | #11 | |
i have it setup for the front two axles to share a single channel (and the cc pro bec) for their two servos while the rear axle servo is a different channel (and a cc bec). it seemed like all the servos got twitchy but i need to confirm. if it was the pair of front axles only could controlling two servos be too much for a single rx channel? | |
10-23-2013, 08:28 AM | #12 |
Since the BEC handles the load, I see no issues with multiple servos off a single channel.
10-29-2013, 02:54 PM | #13 |
Newbie Join Date: Oct 2009 Location: Minnesota
How long are the cables for the BEC's including any extensions. You might be picking up some RF noise and it could be causing the servo driver IC inside the servos to glitch. One way to find out would be to install these. I know its a radio shack item but they do work. Snap Choke Core - RadioShack.com Any time you make a cable longer it acts like an antenna and picks up any extraneous noise. Which could be causing the issue. Worth a 3.00 experiment, good luck. |
10-30-2013, 04:19 AM | #14 | |
10-30-2013, 04:54 AM | #15 |
I would start by grounding the servos.
10-30-2013, 08:50 AM | #16 |
Rock Crawler Join Date: Oct 2006 Location: Fernley
What voltage are your bec's set to? If they are set too high you might not be supplying enough voltage after 10min of run time causing them to glitch. Any chance you can try a 3s on it?
strange electrical gremlin. help! - Similar Threads | ||||
Gremlin vs Prius | BJoe | Chit Chat | 11 | 07-01-2013 02:22 PM |
The Red Gremlin | ripper7777777 | Team Losi Comp Crawler | 22 | 07-02-2009 04:31 PM |
Strange Electrical Issue | JeremyH | Electronics | 8 | 07-04-2008 06:45 AM |
Gremlin or Pacer | Bart bender | Chit Chat | 18 | 02-28-2007 09:52 AM |
