11-04-2013, 12:50 PM | #1 |
Rock Stacker Join Date: Feb 2012 Location: Israel
| HV Servo Jumps Around
Hi, I am running a Hitec HS7954SH on my truck and every time I start off a new battery ( 8.4V) the servo starts to twitch and move very fast for small angles. When the truck is still, the steering works fine, although it starts "jumping" at low speed. It mostly stops at high speeds. Because the servo is rated to run on 2s LiPo, it gets power straight from the battery pack (signal and ground are connected to the Rx). I'm not sure if the problem is the changing voltages or some sort of interference with the signal. Any help will be great! Thanks! Yoraish |
11-04-2013, 03:05 PM | #2 |
Rock Stacker Join Date: Aug 2006 Location: Boone, NC
I believe you need to pull the servo gnd out of the RX and run it directly from the battery as well. Sent from my HTC6435LVW using Tapatalk Last edited by 83GT; 11-04-2013 at 04:37 PM. |
11-04-2013, 05:47 PM | #3 |
| Re: HV Servo Jumps Around
Digital servos tend to "hunt" for "0" with a little load on them. If you lift the steering end of the rig up, the "hunt" tends to stop. With a fully charged pack, the hunting may be more noticeable. Some radios (Spektrum is one) want a common ground between the servo, RX & power source. |
11-05-2013, 01:57 AM | #4 |
I'm with Charlie on this. My servo behaves the same, a little twitchy as it tries to find its zero state. Quite normal. And I have the ground common through separate BEC and ESC (via Rx). |
11-05-2013, 03:11 AM | #5 | |
Thanks for your answers. Quote:
I uploaded a video so you can get a better look at the situation. You can see that the steering works fine in the beginning, but freaks out at low speed. | |
11-05-2013, 06:34 PM | #6 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
u need to add a bec it is causing ur rx is browning out
11-05-2013, 07:29 PM | #7 |
| Re: HV Servo Jumps Around |
11-06-2013, 12:07 PM | #8 |
Quarry Creeper Join Date: Oct 2004 Location: Cow crap flats
Ive found the 7954sh servos dont respond well being hooked directly to the battery. a bec at 7.4 works well. a fully charged 2s is 8.4v which is too much for the 7954sh. I use one in my losi ten scte with out ever a hicup, but fried another hooked direct to the battery in the wraith. A bec is the hot ticket to run on this one for hv.
11-07-2013, 02:18 AM | #9 | |
| Re: HV Servo Jumps Around Quote:
11-12-2013, 06:04 AM | #10 |
powering the servo, no noticeable difference.
HV Servo Jumps Around - Similar Threads | ||||
Viper Lite jumps | jordi555 | Videos! | 9 | 07-16-2012 10:15 PM |
jumps video..... | m3kan1k | Chit Chat | 9 | 02-10-2009 10:26 PM |
dig servo jumps at full throttle? | TWISTEDBYDESIGN | Electronics | 1 | 01-12-2009 10:09 PM |
Truck jumps? | PapaGeno21 | Electronics | 0 | 02-09-2008 05:40 AM |
Another one jumps... | jeep94xj | General Crawlers | 14 | 07-12-2004 12:12 AM |
