11-21-2013, 04:03 PM | #1 |
Pebble Pounder Join Date: Jan 2013 Location: Kentucky
| Reciever: Where To Plug Things In?
I recently bought a Fly Sky GT3b. It comes with a reciever that has 4 slots. In my crawler I need to plug in: 2 servos, Tekin FXR, and a BEC. My questions is, which slots do they go in? Or can they go in any slot? |
11-21-2013, 04:12 PM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: Farmington
| Re: Reciever: Where To Plug Things In?
Generally, channel one is steering servo and 2 is throttle (FXR). The other servo depends on what you use it for and where you assign it on your transmitter. BEC can usually go in any un-assigned slot or it can be wired directly to servo. Look around on forum for BEC wiring diagrams. One important note is that your red wire in the 3 wire lead from your Tekin FXR should not be used in the same circuit as the red wire from the 3 wire lead of your BEC. I usally remove the red wire from the connector on the FXR while some others prefer to direct wire to the servo which is a whole other explanation.
11-21-2013, 06:00 PM | #3 |
Ok, connecting to the FXR there is white, black and red wires connected together....dont use the red wire...ok. But I have 2 seperate steering servo wires? So where does everything go?
Reciever: Where To Plug Things In? - Similar Threads | ||||
New Honcho TR...how to plug in the reciever wiring | rngrchad | Axial SCX-10 | 4 | 02-15-2011 06:56 PM |
Reciever Plug | Tortuga275 | Electronics | 1 | 02-03-2010 09:32 AM |
spectrum reciever - which way to plug in esc / servo | knuckleslammer | Newbie General | 2 | 04-16-2009 07:01 PM |
reciever plug conversions | doomdog666 | Electronics | 3 | 05-16-2008 02:08 PM |
