Thread: Help with Sidewinder 3 Flashing Yellow
Old 11-24-2013, 12:22 PM   #1
Default Help with Sidewinder 3 Flashing Yellow
I'm just about complete with the Wraith kit, but my Sidewinder 3 just beeps with the flashing yellow light. I initially calibrated the ESC last night, and everything worked, so I went to sleep. This morning, no joy. The receiver seems to be working because the steering servo responds.
My setup:
ESC Sidewinder 3 (changed the setting to brushed motor with the CC Field Link Card)
BEC Castle Creations
Motor Axial 20T
Btry 3S 2200mah
Radio/TX Traxxas 27mhz 2 channel TQ3
Asjackman is offline   Reply With Quote
Old 11-24-2013, 12:27 PM   #2
Default Re: Help with Sidewinder 3 Flashing Yellow
are u using the right wire configuration
Ohioskills is offline   Reply With Quote
Old 11-24-2013, 12:33 PM   #3
Do you mean from the ESC to the motor? If so, I'm using two wires from the ESC to the motor.
Old 11-24-2013, 12:39 PM   #4
I just plugged the ESC into the 1st channel and got it to work perfectly, even calibrated it with the steering wheel acting as a throttle. When I plugged it back into the 2nd channel, the yellow just flashes. Is this a bad receiver?
Last edited by Asjackman; 11-24-2013 at 12:40 PM. Reason: To get response notification.
Old 11-24-2013, 02:32 PM   #5
Looking at this..... Castle Creations | FAQ: 1/10th Scale Products , a lot depends on what you're doing.
Charlie-III is offline   Reply With Quote
Old 11-24-2013, 03:16 PM   #6
Try the RX slot right after the one u r plugging into. Same happened to me and most traxxas RX have 2 channel 1 then a channel 2
mcap is offline   Reply With Quote
Old 11-24-2013, 06:08 PM   #7
I plugged in the ESC into Channel 1 and I can fwd/rev/brk with the ESC/motor. Seems like channel 2 is inoperable. The receiver has 3 channels, is there any way I could mod the radio to send the throttle or steering signal through channel 3? The TQ3 radio is a 3 channel (2 position) radio.
I'll try other combinations of channels on the RX
Old 11-24-2013, 10:11 PM   #8
Now channel 1 is not working. I am quitting with the Traxxas RX, could it be possible that the ESC/LIPO has fried the RX? Anyway, ordered a Fly Sky GT3C. Was hesitant about it, but needed something at a low cost. Starting this hobby got expensive... quickly.
Old 11-25-2013, 08:10 AM   #9
If you have the internal ESC BEC to the RX (and not an external BEC to the RX) then the ESC will output a safe voltage to the RX. It won't matter what the battery voltage is (short of overvolting the ESC which can cause it to fail).
The internal BEC outputs voltage through the ESC to RX wires.
Old 11-25-2013, 08:50 AM   #10
I am using a CC BEC, did that fry it?
Old 11-29-2013, 06:51 PM   #11
Everything works now that the GT3C has arrived.
Old 11-30-2013, 07:25 AM   #12
What voltage was the became set on? If it was more than 6 volts it may have fried the receiver.
hatefulboy is offline   Reply With Quote
Old 11-30-2013, 07:30 AM   #13
I just checked, it was at 5.1, I just increased it to 6.0 using the GR3E rx.
Help with Sidewinder 3 Flashing Yellow - Similar Threads
leds flashing jeepscx10 Electronics 3 03-10-2013 06:11 PM
PLEASE HELP Esc flashing Lilred Electronics 2 06-13-2010 08:25 PM
Rooster and RX flashing... Greatscott Electronics 1 12-02-2009 11:34 PM
Flashing LED's BlueMonster Electronics 0 02-11-2008 11:02 PM
Looking for red flashing L.E.D.s TREVORS_DAD General Crawlers 4 08-06-2006 02:05 PM
