10-25-2006, 09:49 AM | #1 |
Rock Crawler Join Date: Nov 2004 Location: Driving the Troysion Stick up the BIG BOY line!
| Elite 4500mah SC
Anyone running these? I just ordered 8 of them from Cheapbatterypacks based on their performance graph and the price. They look to slightly out peform the IB4200s as far as continuous output.
10-26-2006, 09:57 PM | #2 |
Rock Crawler Join Date: May 2004 Location: Calgary
I'm running them in my onroad cars, and they are great! Tonnes of punch, and excellent run times.
10-27-2006, 01:09 AM | #3 |
Yea, I just got done putting them on my clod, I've got 4 on each axle. Fit good, and look good, just doing the first inital sloooowww charge at .2 amps..
10-27-2006, 12:45 PM | #4 |
Using the initial slow charge formula, C/10 gets you a 450 mah charge for 14 - 16 hours. You should bump up from the .2 to .4 for 16 hours , or maybe .5 for 14 hours. |
10-27-2006, 12:58 PM | #5 |
True, but I started them at 1:30 AM and won't be home to check them till close 6 PM tonight. So, I'll see how they did. Thanks for the reminder on the formula, though.
10-27-2006, 01:18 PM | #6 |
My guess is they might not even be close to 4500 mahs. C/10 = charge rate for ~14 hours 4500/10 = 450 4500 = 10 * 450 2000 = 10 * 200 Tack on another 1000 mahs, you're still a little shy of 4500. |
10-27-2006, 01:24 PM | #7 |
RCC Addict Join Date: Jan 2005 Location: Germany north
the new generation of cells like more amps 1C initial charge is ok they dont like discharge lower than 1V per cell ! thea are good cells for racing , but i think you will kill them in a crawler |
10-27-2006, 01:25 PM | #8 |
| I just called home and had the wife check since it's been 12 hours..... 2351 mah so far. So about another 12 hours at .2amp I'll also put up some pics tonight since we were discussing these via PM. |
10-27-2006, 04:59 PM | #9 |
Pebble Pounder Join Date: Sep 2005 Location: Columbus
I am running these, 6 cells brick pack on my clod seem to be a good battery. Long run time i get about an hour and 15-30 min all depending on how i am driving.
10-27-2006, 08:09 PM | #10 |
Still charging...... Here's a couple of pics. |
