10-29-2006, 01:16 AM | #1 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
| "big Dx6 Headaches"
Ok I have a DX6, Mamba25, Revolver BL, and canot get anything to work? I tryed a difrent Radio/rec and I could atleast get the Mamba to somewhat program. Why can't I get anything to work with my DX6?:-( It acts like it's not binding to the REC, I've already sent it back once because of the same problem and they were supost to fix it they said it was a bad REC and sent it back with a new one and nothing....
10-29-2006, 01:37 AM | #2 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
What's the deal? Nothing works with the '6? Or nothing works with any model TX? It may seem stupid but do you have juice in the battery on the rig? My boy has a DX-6 and it binded pretty easy.........
10-29-2006, 01:43 AM | #3 | |
10-29-2006, 01:50 AM | #4 |
Pebble Pounder Join Date: Oct 2006 Location: belgium, roeselare
you can bind it with only a battery pack hooked on your receiver, i did mine (dx2) like that. |
10-29-2006, 01:04 AM | #5 | |
10-29-2006, 01:07 AM | #6 |
Well I'm gonna try the rec pack and if that don't work I'll probably use it for target practice. Just pisses me off when you spend alot of money for this shiat and it dosn't work.:-(
10-29-2006, 02:21 AM | #7 |
Good news! I finaly got it to bind. Now I may have some ESC problems. It smelled like it was getting hot prety quick. I've never ran a Mamba25 so not sure how hot is normal. |
10-29-2006, 08:48 AM | #8 | |
10-29-2006, 12:47 PM | #9 |
I know there's an issue with Mambas and Spektrum, but I also know that they can and do work together. I think you need to bind with an rx pack. After that it should be fine.
10-29-2006, 08:04 PM | #10 | |
10-29-2006, 08:57 PM | #11 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
I've been using a DX6 with my Mamba/Revolver combo since...well...the first brushless Clod was built. I pre-programmed the Mambas using the CastleLink. Install the bind plug into the AR6000. Plug the Mamba to the batt. Turn the Mamba on. Hold the bind button on the back of the DX6 and turn it on. Continur holding the bind button until it flashes. Wait and watch the LEDs on the AR6000...when it goes solid you're good. Remove the bind plug and crawl. Last edited by JasonInAugusta; 10-29-2006 at 09:04 PM. |
10-30-2006, 11:03 PM | #12 | |
