01-18-2014, 06:36 PM | #1 |
Newbie Join Date: Oct 2013 Location: Australia
| bec needed?
Hi guys. I was out crawling the last few days and my car keeps turning off? Only when im in full steering lock and full throttle. Its really annoying! Then my intergy brushed 55t started smoking! I do have a new tekin 35t but don't want to fry it lol. Esc is a tekin frx? And servo is servo safe. Any ideas. Bec? What one? |
01-18-2014, 06:42 PM | #2 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
| Re: bec needed?
Thats what it sounds like but i don't know why your motor would be smoke'n
01-18-2014, 06:45 PM | #3 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: bec needed?
A Castle Creations BEC will solve the intermittent turning off when your steering and gassing it at the same time. The motor smoked probably because your gearing is all wrong or your motor was incredibly dirty. What is your gearing? Also, what battery are you running and what vehicle do you have? |
01-18-2014, 06:48 PM | #4 |
Quarry Creeper Join Date: Dec 2009 Location: West Alabama
| Re: bec needed?
EDIT: I type entirely to slow... sounds like you do need a bec. Castle 10A should work fine. what has me concerned is that smoked motor. could have been caused by the frequent power drops, which would be fixed by adding the bec and the tekin motor you already have. could have been the motor going bad causing issues in the esc, and therefore shutting down power to the truck. new motor and bec should fix this as well, but would question whether esc has been damaged in this case could have been an issue with the esc going bad, dropping power and frying the motor. motor and bec wont fix the esc, and could fry the new motor too then it could have just been a little dust in the motor that caused the smoke (if it was very light smoke) and you just need a bec |
01-18-2014, 06:50 PM | #5 |
Quarry Creeper Join Date: Sep 2010 Location: In the pre-game lobby
| Re: bec needed?
The nice answer is, a castle creations 10amp bec, set at 6volts. Bout 20$. But my answer is, did ya see the sticky near the top of this forum? The one that reads "YES, YOU NEED AN EXTERNAL BEC!!!"?? READ IT. |
01-18-2014, 07:00 PM | #6 |
| Re: bec needed?
Thanks guys. Its geared at 14t 87t. I run 3s lipo. Where is the cheapest place to get a bec? Also yes I did read the other topic on bec but I got confused hhaha. |
01-18-2014, 07:06 PM | #7 |
| Re: bec needed?
Rpp has them for 19.99
01-18-2014, 07:06 PM | #8 |
| Re: bec needed?
Also my motor sounds very loud now. But only under strain. Its possible its dirty as I go through deep mud and water. But I always clean it after a run in water or mud
01-18-2014, 07:08 PM | #9 |
| Re: bec needed?
Can I ask what rpp stands for? Sorry for my question
01-18-2014, 07:09 PM | #10 |
| Re: bec needed?
The bearings don't like that at all , May want to get yourself a new one of those when you make your order.
01-18-2014, 07:10 PM | #11 |
| Re: bec needed? |
01-18-2014, 07:12 PM | #12 |
| Re: bec needed? RPP Hobby | Radio Controlled Cars, Trucks, Boats, Helis, Planes, Plastic Models Its one of the best on line hobby store. You'll find anything you need there. |
01-18-2014, 07:25 PM | #13 |
| Re: bec needed?
Ok im on the site now. So the 10A one? Or the pro one? Will it be fine with a 3s lipo |
01-18-2014, 07:58 PM | #14 |
| Re: bec needed?
The 10A is all you need.
01-18-2014, 08:00 PM | #15 |
| Re: bec needed?
Ok thanks.. the good thing is having 3 rc cars. So when one is broken I can use a different one haha.
01-18-2014, 08:06 PM | #16 |
| Re: bec needed?
Thats a good thing. |
bec needed? - Similar Threads | ||||
I have CC MMP, Is a BEC Needed? | dAng! XJ | Axial Wraith | 6 | 08-10-2012 01:14 PM |
!!CC BEC Help needed!! | LabRat 4x4 | Electronics | 8 | 05-05-2010 07:41 AM |
need to know if a cc bec is needed! | jon1197 | Newbie General | 9 | 01-29-2010 06:35 AM |
