10-29-2006, 02:17 PM | #1 |
Rock Stacker Join Date: Sep 2006 Location: Corning
| Do I need a Regulator
I was just at the hobby shop picking up the last pieces for my tlt and the guy mentioned that I might need a regulator for my servo. I am going to be running a hitec hs-645mg. I have a futaba cr330 esc and a traxxas reciever? Do I need one? And if so where do i put it. |
10-29-2006, 02:35 PM | #2 | |
Newbie Join Date: Oct 2005 Location: SE PA
10-29-2006, 03:23 PM | #3 | |
RCC Addict Join Date: Dec 2004 Location: Central NY
10-29-2006, 03:25 PM | #4 |
My receiver is only hooked up to my esc by the 3 wire plug. Not connected to battery directly. So your saying no regulator needed then? Thanks for the info |
10-29-2006, 08:30 PM | #5 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
You should be fine without it if you are just running the one servo. The only time you need a regulator or reciever pack is when you are running two or more high drain servos |
