10-30-2006, 08:27 PM | #1 |
Newbie Join Date: Oct 2006 Location: StatenIsland NY
| Max MaH esc's can take
how exactly can i figure out what a esc's max MaH battery it can take , forinstance im picking up a novak super duty XR and was going to get a lipo with a lowvolt safty on it also , but how can i tell whats the highest mah battery it can handel with out burning out . thx
10-30-2006, 08:57 PM | #2 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
I don't think you quite understand what Mah is. It is milli amp hours, it is a unit of capacity, you can have a 1,000,000 Mah battery and it won't be any different than a 1900 mah battery to your esc. The voltage is what will cook an esc, just stay within the voltage limit and you should be fine.
10-30-2006, 09:00 PM | #3 |
i was just cerious becouse becouse i saw a esc that said it could run up to 4500mah . so it got me very confused .. just wanted to conferm . thx for ur info
10-31-2006, 02:13 AM | #4 |
Pebble Pounder Join Date: Oct 2006 Location: belgium, roeselare
thats cuz of the runtime, some racing esc are made to run only 5 or 8 minutes and if you'd drive longer they heat up to much with racing gear ratio's. if you where to gear em down they'd hold up for longer periods. i hope i made some sense. |
