02-01-2014, 09:51 PM | #1 |
Rock Stacker Join Date: Jan 2014 Location: salem
| bec to servo advantage
what is the advantage of wiring my bec to the servo instead of the rx?
02-01-2014, 10:13 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: bec to servo advantage
So the servo gets the full voltage you set the bec to. Some Rx's can't operate on high voltage, so this would limit the power going to the servo if you powered the servo through the Rx.
02-01-2014, 10:38 PM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
Yea like Johnny said, if you have a servo that can take 7.4v then you would want to wire it direct, otherwise if your just using a regular servo good to 6v you could go either way.
02-01-2014, 11:16 PM | #4 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
I run my BEC set at 9 volts through my futaba rx without issue.
02-02-2014, 01:47 AM | #5 |
Some are just don't want to pull the red wire from their ESC's connector, and find it easier to just go straight to the servo. On a related note, anyone who's bought a Receiver Bypass Adapter has seen how crazy-simple it is to run it that way, and just does a plug-n-play. Some have found that even when done correctly, they can still draw enough through the receiver that the voltage can drop off and brown out the receiver. Some actually do believe they're losing power by going through the receiver. So who knows, could be any of a number of reasons why people do it one way or the other. I've got one still running through the receiver, and two that I've built receiver bypass adapters for, both ways are workin' fine for me. Do it whichever way you're comfortable with. |
02-02-2014, 08:51 AM | #6 |
thanks fellas!!!!Il pick up a bypass adapter and call it good...i love this forum
02-02-2014, 10:25 AM | #7 |
Quarry Creeper Join Date: Sep 2013 Location: post falls
Anyone know where to get an rx bypass? I know Holmes has them but they're out of stock there.
02-02-2014, 10:32 AM | #8 |
I don't think they are being produced anymore. Just make your own from a Y connector.
bec to servo advantage - Similar Threads | ||||
how do i know if i need a new servo and a bec?? | Willyb211 | Electronics | 20 | 06-13-2013 09:25 AM |
BEC for HV servo? | Bansh88 | Newbie General | 19 | 02-26-2013 12:10 PM |
New servo and BEC | Losi man | Losi Mini-Rock Crawler | 5 | 04-14-2010 06:20 AM |
BEC's? whats the advantage? also, what servo | axeten | Electronics | 12 | 12-15-2009 06:29 PM |
