Thread: Sidewinder or MMP
Old 03-17-2014, 04:33 PM   #1
Default Sidewinder or MMP
Im just wondering what the difference is if any between a sidewinder v3 and a MMP in brushed mode. I have both already. The MMP is in my stampede with a sensored motor. I like having the sensor in the pede so it is smooth at slow speeds. The sv3 is in my scx based bronco build. The scx is getting pretty heavy tho. Im running a 35t brushed motor now but it will soon be a 55t brushed with a 2 speed tranny. Is the sidewinder strong enough for this truck or should i swap them out. The pede is only 2wd and very light weight compared to the bronco. I just like the smaller size of the sv2 in the scaler so its easier to hide. And i like the stupid fast and smoothness of the MMP in the pede. Any input is greatly appreciated thanks!
Jcplante is offline   Reply With Quote
Old 03-17-2014, 04:56 PM   #2
Default Re: Sidewinder or MMP
I dont think there would be a noticeable difference between the two with a brushed motor. unless you want to run more than 3s the sidewinder should do just aswell brushed.
littletoyboy is offline   Reply With Quote
Old 03-17-2014, 05:47 PM   #3
Thats what i was hoping but i wasnt 100% just cause the MMP is so much bigger. I thought maybe it had a higher amp rating. I would hate to kill the sv3 for no reason lol
Old 03-18-2014, 09:51 AM   #4
I am in agreement. Very little difference at all, and in brushed mode, should probably be nearly identical, as the castle link setups are as well.
tgh117 is offline   Reply With Quote
Old 03-18-2014, 10:13 AM   #5
I like that the Sidewinder is smaller (but I wouldn't exactly call it small), cheaper and waterproof. Fitted one in a SCX10.
Odd-M is offline   Reply With Quote
Old 03-18-2014, 01:08 PM   #6
Great thank you all for the input. I feel safe running the way i am now after hearing from you all.
Sidewinder or MMP - Similar Threads
CC mmp vs mmp sct edition? mudd_slinger Electronics 5 06-05-2013 01:18 PM
sidewinder with a cc bec,works great but Can I swap it out for a Micro sidewinder? username Electronics 3 04-04-2009 10:11 PM
