03-29-2014, 10:25 AM | #1 |
Pebble Pounder Join Date: Dec 2012 Location: Missouri
| Possible problem with Holmes brushless motor
I just got the trailmaster brushless motor in and hooked it all up. Running a 11/54 32p gear setup in my scx10. It's hooked to a mmp. In smart sense or sensored only mode , the motor has a very pronounced hesitation when going from a dead stop to wide open. Sometimes to the point that the truck just stops moving completely. Motor timing is set to 0, and startup is set to low, running a 3s 30c 2600mah |
03-29-2014, 10:27 AM | #2 |
| Re: Possible problem with Holmes brushless motor
The motor acts completely normal with the sensor wire out and I have tried two different sensor wires with the same results.
03-29-2014, 10:56 AM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
Sounds to me like an issue with the sensor board. You will have to contact Holmes about that most likely.
03-29-2014, 02:01 PM | #4 |
Rock Crawler Join Date: May 2010 Location: Bedford Ky
Definitely a sensor issue contact jrh and he'll get you squared away. I had to send my outrunner back for a sensor problem and now I works flawlessly.
03-29-2014, 03:44 PM | #5 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
i have to run mine with sensored only on my mmp tekin and mmp and hh.
03-29-2014, 04:11 PM | #6 |
Yea, does it on sensored only as well
Possible problem with Holmes brushless motor - Similar Threads | ||||
Problem with Holmes Motor | fastlosi | Electronics | 9 | 04-10-2009 09:47 AM |
