Thread: Motor shorting on bolt for rock slider mount.
Old 04-08-2014, 01:55 PM   #1
Default Motor shorting on bolt for rock slider mount.
I seem to be having an intermittent problem with my new Tekin FXR 35T COMBO that I just recently installed.
Sometimes I lose all throttle or throttle is not at proper RPM. The ESC is showing the proper throttle range but there is no output to the motor. The motor wires are soldered solidly in place.
It appears to be linked to the motor's brush wire coming into contact with the nut/bolt combo that holds one side of the rock slider mount. If I push this wire a little further away from the bolt, full throttle returns.
I was thinking that maybe you could paint the wire with some clear nail polish or something to shield it a bit but wasn't sure if that would damage anything.
I came from the stock 27t motor which is a sealed end bell and didn't have this problem.
What are you all doing to eliminate this wire from coming into contact with the chassis?
Thanks for your help.
Sent from my SCH-I545 using Tapatalk
DowntownScience is offline   Reply With Quote
Old 04-08-2014, 03:20 PM   #2
Default Re: Motor shorting on bolt for rock slider mount.
use a little shoogoo....nail polish isn't gonna work like you want.
Later EddieO
EddieO is offline   Reply With Quote
Old 04-08-2014, 03:25 PM   #3
Use the other set of holes on the mounting face of the motor.
Calderwood is offline   Reply With Quote
Old 04-08-2014, 04:31 PM   #4
Yup or rotate the motor by using the other set of mounting holes in the can.
WHITE-TRASH is offline   Reply With Quote
Old 04-08-2014, 05:13 PM   #5
Yeah...guess I just need to pull the motor and see what I can do about moving the wires away from the chassis.
Someone had mentioned plastic nuts instead of metal and I was just curious what everyone does to combat this problem. (no pun intended)
Old 04-09-2014, 02:40 PM   #6
I flipped the bolt around and put the nut on the outside of the chassis.
realsickclown is offline   Reply With Quote
Old 04-10-2014, 08:30 AM   #7
I'm such a bonehead. So I flipped the motor completely and used the set of holes that kept the can furthest from the chassis. Now both brushes are visible and far from contacting the chassis. Thanks for all the suggestions.
Motor shorting on bolt for rock slider mount. - Similar Threads
Motor Shorting to frame Yorkster Axial SCX-10 7 12-30-2011 08:44 AM
Novak Ballistic Motor Mount Bolt Pattern Drawing sunworksco Electronics 2 11-02-2009 12:03 PM
