Thread: Need help
Old 04-08-2014, 06:46 PM   #1
Default Need help
Upgraded my wraiths Esc to a mamaba max pro an motor to tekin pro 13.5t brushless motor few weeks back , Monday did some bashing after work performed great never had an issue , today after I installed new tires on it went to try them out truck starts freaking out won't respond to my controller an the Esc is flashing red have a red light on the receiver which is stock axial product , now it does nothing . If I power the Esc up it goes threw its normal beeps I have no steering either all my batteries are fresh an new I'm lost an idk what to do
camogonewild is offline   Reply With Quote
Old 04-08-2014, 06:59 PM   #2
Default Re: Need help
Try and set your throttle trim , as you turn the knob look at your esc lights to see it they change colors.
old man 52 is offline   Reply With Quote
Old 04-08-2014, 10:15 PM   #3
Nope nothing I do with the radio has any input at all to the truck throttle or steering
Old 04-09-2014, 06:28 AM   #4
I guess you could try and rebind your radio to the receiver and see if that helps the problem.
You should get 2 sets of tones from the motor, first set for turning on, second set for arming the ESC.
If you are not getting the second set of tones, then your esc is not arming, due to the throttle being not in the zero trim, or an issue with the receiver.
I would try and rebind the receiver first, and then work from there.
tgh117 is offline   Reply With Quote
Old 04-09-2014, 07:15 AM   #5
Yes you need an external bec
The Violator is offline   Reply With Quote
Old 04-09-2014, 06:37 PM   #6
Well here's another kicker took it to work after work I said I'd give it another didn't do any thing to it switched battery on an it acted fine for about 30 mins then started acting weird again started acting glitchy steering Spraticly jumping forward on its own not responding to remote turned it off then back on Esc did it's first set of tones then truck went to acting weird Esc flashing red green yellow ligbts
Old 04-10-2014, 09:20 AM   #7
Maybe when the car had a nice full charge the mmp, which is known to have the worst bec to ever be installed into a product probably it was a stolen Novak design, it would scrape by.
Of course your problem has been resolved on this board at least 5x a day for the last 5 years, and even resolved in this thread.
Old 04-10-2014, 02:58 PM   #8
Ok I'll get a bec next week an try that
Old 04-10-2014, 03:42 PM   #9
do you have a red and green light on top of your transmitter?
disconnect your servo and try just the ESC into the receiver. See if your servo is creating feedback issues.
P.S. The Axial receiver is known for taking a poop without warning
redsawacs is offline   Reply With Quote
