11-26-2006, 12:51 AM | #1 |
Rock Crawler Join Date: Nov 2005 Location: Fremont/Newark, California
| Quark Procar 33A....getting HOT!!!
This thing is getting hot....after a few minutes its almost too hot to touch. Anyone else having these issues as well? Pede tranny with 12/87 gearing in a sw2 w/tlt axles. Park 400 740kv motor Battery is a 3 cell lipo 1800mah 11.1V Spectrum dx3 radio hi-tec 5995tg servo ESC settings are as follows: Direct reverse 100% Brake li-poly hi for battery selection outrunner drag brake on race mode noise cancel off torque is set to dynamic delayed brake/reverse is set to .2 seconds narrow neutral range SicJ is running same exact setup and his heat sink is much cooler after thrashing on it. Thanks Brian |
11-26-2006, 07:37 AM | #2 |
Are you running different tires than SicJ? Is your drivetrain as easy to turn? driveline angles not binding any, etc? What is the temp of the motor? Have a temp gun?
11-26-2006, 02:09 PM | #3 | |
Thanks Brian | |
11-26-2006, 04:14 PM | #4 |
RCC Addict Join Date: Jan 2005 Location: Green River Kentucky
Mine was getting hot with the park 400 on 8 ib 1400 cells so I removed 1 cell and its fine now never even gets warm.I did notice when I had the 8 cells as long as I was giving it alot of throttle it was fine but when I was trying to crawl real slow is when it got super hot.
11-26-2006, 10:02 PM | #5 |
Quarry Creeper Join Date: Dec 2004
it is weird.... I've been running the quark and park 400 with a 3 cell 1500mah LiPo for about 3-4 months now and have not had a problem. That why I recomended it to him. The only time mine got as hot as HD2500's was when I had the batt setup on the ESC set to "Nimh High" and I was using a LiPo....switched the battery setting to "LiPo high" and the temps dropped down to normal. His esc has to be getting around 150*+ this is his 2nd ESC so I think it has something to do with the motor.... unless your not on the "LiPo high" setting |
11-30-2006, 08:19 PM | #6 |
took it out today to see what the temps were after a few minutes of running around. the motor never got above 65° the esc got to about 111°. No binding in the axles or the drivelines. The mesh is set correct on the pinion/spur. I even reprogrammed it. For those of you using the esc, when throttle is applied what color does the led light up? |
12-02-2006, 07:03 PM | #7 |
Traxxas spur adapter was rubbing on the stampede case. I didnt add the supplied washer and i guess the little bit of friction was too much for the esc. ran it for about 10 minutes and esc ran cool.......
12-02-2006, 07:19 PM | #8 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Maybe you servo is sucking hard on the BEC.
12-03-2006, 08:22 PM | #9 |
Possibly, last night I thought I had fixed the problem . Went out today and did it again. 2nd speed controller....well see.
