11-26-2006, 11:46 PM | #1 |
Newbie Join Date: Nov 2006 Location: San Mateo
| esc help
I have a LRP Runner Plus Reverse and I was wondering if would be able to handle dual motors and dual servos. I read that the BEC should be atleast 3amps but the spec were rated in volt and im not sure is it able to handle it. Here is a link to the specs of the ESC. http://www.lsarc.com/forums/showthread.php?t=29 If its not im just gunna buy a Moped. Do you wire the motors in parallel??? Thanks for the help! Sean |
11-27-2006, 01:02 AM | #2 |
I've read that these have a long delay going to reverse. Yes parallel.
11-27-2006, 08:22 AM | #3 |
But will it work for a dual motor and dual steering set-up or is the BEC rating to low? Thanks for the help!
