11-27-2006, 12:58 PM | #1 |
Pebble Pounder Join Date: Dec 2005 Location: Somewhere in Sweden
| Traxxas EVX
I wonder if you can put two 8,4V or two 9,6 batteries in a Traxxas EVX without it'll break?
11-27-2006, 02:15 PM | #2 |
Rock Stacker Join Date: Sep 2006 Location: Port Angeles
I think they can only handle up to 14.4v look on towerhobbies.com and it will tell you the specs at the bottom of the page.
11-28-2006, 01:38 AM | #3 |
Quarry Creeper Join Date: Nov 2005 Location: Planet Earth
All the evx's I've checked stop at a max votage of about 22 - 23 volts. Mostly use 5 cells on the esc/servo plug and the balance of the 5-16 cells on the dummy side plug. That is 5-16 cells total. The esc/servo side can take at least 8 cells if that's what you want. |
11-30-2006, 12:21 AM | #4 |
I didnt understand a word in that reply lol. Could u dumb that down for a newb/idiot? How many volts can i put into after it blows up? Could i put in two 8.4v packs?
11-30-2006, 05:55 AM | #5 |
Pebble Pounder Join Date: Nov 2006 Location: Nor Cal
Yes, you can use two 8.4 volt packs with an EVX. Check e-bay or any battery supplier for e-maxx battery packs and many of them make a E-Maxx pack with 7 cells. I have a couple sets myself and have used them without any issues. I don't know about 9.6 though cause I've never used them.
11-30-2006, 09:48 AM | #6 |
sorry, I try again. Seperate the two connectors to speak voltage. The connector that powers the esc/servos can use 6 - 12 volts The other side (dummy side) can use 0 - 16 volts Put them together in any configuration for a total of 23 volts The best configuration is to use the 5 largest cells on the esc/servo plug and then use the balance of your cells on the dummy side plug. I like to use 5 + 12 or 5 + 11 or 5 + 10 or 6 + ?? |
11-30-2006, 10:16 AM | #7 | ||
rkrawler and floogldood, thank you very much for the answers! kweezy, I know, my English is farly bad. But it's not so strange, bearing in mind that my mother tongue is Swedish and that I don't got good marks in English in the school. By the way, your English is not perfect either! Quote:
11-30-2006, 07:42 PM | #8 |
Sorry i forgot to capitalize the i . I wasnt trying to dis on ur english lol, i was trying to ask you to make it simpler so i could under stand.
12-01-2006, 07:27 PM | #9 |
Rock Crawler Join Date: Aug 2006 Location: On the trail
i use two 8.4v on my emaxx............perfect..goes toooo much fast compared to the 7.2v |
