Thread: MG995 X2... voltage regulator amps??
Old 11-28-2006, 08:53 PM   #1
Default MG995 X2... voltage regulator amps??
I am planning on running a moped ESC with two MG995 servos on clod axles, with 7.2 volt battery input. My question is will a 1 amp regulator handle one of the servos (running the other off the ESC)? Should I parallel the regulators for say 3 amp and run both off of the battery and leave the ESC seperate from the servos? Yes I know the ESC only has a 5V BEC compared to the 6V I would be running with the regulator. I was just looking for some input on this since the search did not quit answer what I was looking for.
Thanks, 64DUECE
64DUECE is offline   Reply With Quote
Old 11-29-2006, 04:04 PM   #2
Does anyone have a rough idea of the amperage required to run one of these servos at 5-6 volts??
Old 11-29-2006, 04:20 PM   #3
I lost my vendor privileges
ive been running 2-995's for a couple of weeks now. i have evx 14.4v and rx pack for the servos. 6v on them. got another evx today. u know whats next. 2 evx's 14.4? or 28.8? 2-55 turn axles snappers, 8 tooths, xl's, torquey.
clodstall is offline   Reply With Quote
