10-19-2014, 07:36 AM | #1 |
Rock Stacker Join Date: Aug 2009 Location: Munfordville
| rs10 esc question
Hey guys, I have a Venom Creeper a roller. My buddy gave me an esc that came out of a rs10. I know its a motor on axle esc with 4 wires coming out for the motor. I was just wanting to know if you can just do away with 2 of the wires and use like that? Any help on this would be greatly appreciated.
11-10-2014, 02:05 PM | #2 |
Newbie Join Date: Jan 2013 Location: The mtns of
| Re: rs10 esc question
Absouletly just cut one pair off- they are soldered to the same pads
11-10-2014, 09:11 PM | #3 |
Quarry Creeper Join Date: Dec 2012 Location: Remember, wherever you go. There you are.
Flyguy is right about the wiring. Just make sure you do something to the wires you cut. So they don't short out anything. And I wouldn't run lipo power to that esc. 7.2 nimh only. I tried 2s in my rs10 a few years ago aND it let the smoke out. |
11-11-2014, 07:54 AM | #4 |
Pebble Pounder Join Date: Jun 2014 Location: White Plains
I have never had an issue with 2S LiPo, in fact I run 3S LiFePo4 (9.9v.) The Lansau ESC in the RS10xt is built to support 2S LiPo as it has a 6v LVC built in (you can disable it) The manual is on the redcat website. I know of a few that run 3S LiPo, but you run the risk of letting the magic smoke escape, more often than not the extra power causes the diff pin to strip through the plastic locker plate, I learned the hard way. If you bump the input voltage you need to use a BEC and rewire the fan to the BEC because it runs off batt voltage. The extra voltage will burn up the fan which will allow the ESC to overheat. MAGIC SMOKE WARNING: DO NOT USE THE INTERNAL BEC IF YOU EXCEED 2S LiPo!!!! I bought a 2nd ESC and run dual ESC on my RS10xt, both driven by a 9.9v batt capable of 120 amps of continuous output. I've run it for hours straight with no issues. Be warned if you do run more than 2S LiPo you void the warranty. |
rs10 esc question - Similar Threads | ||||
New to the scene and have a question about rs10 vs rs10 XT | sky56 | Redcat Crawlers | 18 | 03-02-2013 07:24 PM |
Newbie question about RS10 XT - ESC | Pat M | Redcat Crawlers | 7 | 10-05-2012 06:00 PM |
RS10 XT ESC Question | viivtodo | Redcat Crawlers | 3 | 07-01-2011 09:18 AM |
RS10 Motor and Esc Question | foxmx07 | Redcat Crawlers | 11 | 11-16-2010 07:36 PM |
