12-02-2006, 10:16 AM | #1 |
Rock Stacker Join Date: May 2004 Location: Indiana
| Weak MG645??
I am running a TXT with dual steering and dual Hitech MG645's. I run a SR and LST's on maximizers. The problem I am having is the even on smooth rocks the servos will not turn the tires until I move. I have an extra reciever pack and was wondering if I should use it for more juice or if I just have too much tire. Thanks for any input.
12-02-2006, 11:16 AM | #2 |
Quarry Creeper Join Date: Jan 2006 Location: ---EAST--TN---
I dont think you have too much tire - just not enough servo Im my experience the 645s are mediocre. They do ok and are fairly inexpensive, but are not that strong, and gears seem to strip easily. I would try the receiver pack and see if it helps, but I think in the long run you will be looking for better servos. |
12-02-2006, 02:27 PM | #3 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Yeah with your setup you need a servo at least in the 200oz. range.
12-05-2006, 05:38 AM | #4 |
Ok thanks. What is a good servo in that range or should I jump to a 1/4 scale servo?
12-05-2006, 06:33 AM | #5 |
Rock Crawler Join Date: Jan 2004 Location: Round Rock, TX
Are you using a servo saver? The highest torque servo you can find isn't going to do any better with a weak saver.
12-05-2006, 04:39 PM | #6 |
No, I am using aluminum steering horns.
12-05-2006, 07:48 PM | #7 |
Rock Crawler Join Date: May 2006 Location: san diego
Hitec 5955 has over 300 oz of torque cost 115$ You probably need to run a rx pack with these |
12-05-2006, 09:50 PM | #8 |
Keep in mind though,digitals are better off if you have EPA's on your radio. I run the 359's and love'em. |
12-06-2006, 04:05 AM | #9 |
Hitec 5955mg $92 shipped on ebay right now.
12-06-2006, 05:46 AM | #10 |
Well I guess I will have to bite the bullet and buy a pair. Thanks for the help
12-06-2006, 06:18 AM | #11 |
Quarry Creeper Join Date: Jan 2005 Location: Carlisle, KY
You should make some mounts and run some giant scale servos. I run the Hobbico cs-80s on my clod and you can't stop them. http://www2.towerhobbies.com/cgi-bin...&I=LXLN93&P=ML 343 oz-in of torque for 30 bucks! |
12-06-2006, 08:03 AM | #12 | |
Newbie Join Date: Sep 2006 Location: piedmont, al
12-06-2006, 06:14 PM | #13 |
Pebble Pounder Join Date: Mar 2006 Location: hillsboro
I have the same set up with the cs80 and also run a rx pack. This servo moves those size tire with authority.
12-07-2006, 10:23 AM | #14 |
I had some hitec 1/4 scales but sold em. They were crazy strong. I was just trying to keep a small serco. I have a rx pack so I guess I will step up to the cs80.
12-07-2006, 04:49 PM | #15 |
Rock Crawler Join Date: Mar 2006 Location: Auburn, WA
645MG's aren't good for much. Sell them now before they strip out, and you have to spend $15 each just so that you can sell them. I've got a 5995 in my Clod and love it, but like they said, you need EPA for digital servos. If you are on a tight budget, and can fab the mounts, I would seriously look into the 1/4 scale servos.
12-15-2006, 10:25 AM | #16 |
Well I ordered up some CS-80's. We will see how well they can hack it. Thanks for all the input.
12-15-2006, 07:48 PM | #17 |
Rock Stacker Join Date: Dec 2006 Location: Jacksonville
| wonder if I can fit them on my clod ?I just bought two hitech 645's ,damn
