12-02-2006, 07:45 PM | #1 |
Pebble Pounder Join Date: Jun 2006 Location: Massachusetts
| ESC overheating and Motor Gets hot
for a while ive been having problems with my esc overheating. its a LRP AI Quantum Runner Reverse. It seems like it takes alot for the motor to get my Maxx crawler moving. My crawl ratio is 47.46, with 11/72 gearing. Should i run a GD600 on it? I am running a maxx trans locked in first
12-02-2006, 08:30 PM | #2 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Yes, Maxx crawlers need a GD600. You didn't mention....what motor? |
12-02-2006, 08:43 PM | #3 | |
Thanks | |
12-02-2006, 11:52 PM | #4 |
Just guessing,I'd say the 2.5 would put you about right with that motor. I'd also recommend getting a few different pinions to try. You also need to figure in the number of cells your running. Adding cells will generally let you run a little taller gear for more wheelspeed but the low end power will be better as well. Depending on how many cells you run....you might go up or down a tooth or two on the pinion to find the ratio you like best. Everyones a little different and runs a little different ratio that suits them best. My son runs a 27 turn,3.0 GD,66 tooth spur and a 12 tooth pinion. I can't remember exactly what his ratio is but it's somewhere in the 80:1 range. For a little 27 turn brushed motor,I feel that around 80:1 is a good combo of wheelspeed and low end if you run 8 cells or more. Or you can eliminate the reduction and just run a big outrunner My ratio in my truck is 64:1 and it rocks on 8 cells. 9 cells might be better though |
12-03-2006, 07:06 AM | #5 |
right now im running 6 GP3300's and it gets good runtimes, i might go up to 7 cells.
