11-28-2014, 10:02 PM | #1 |
Newbie Join Date: Nov 2014 Location: Flippin
| Esc question
I am somewhat new to the rc world, recently bought an ax10 with ar60 axles in it and have done some minor upgrades My esc is glitchy and turns off by itself a lot so I'm looking for a new one I'm 15 and do not have a job, so I have roughly 70 dollars to spend on one Any input would be greatly appreciated! |
11-28-2014, 11:04 PM | #2 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
| Re: Esc question
Welcome! Check all your wire connections first then next time you run it if is shuts off feel it to see hot hot it is. What esc is it? |
11-29-2014, 10:03 AM | #3 |
Newbie Join Date: Nov 2014 Location: oahu
| Re: Esc question
Ae5 esc essiest to switch from lipo to nihm
11-29-2014, 02:09 PM | #4 |
| Re: Esc question
Which situations make it glitchy and turn off? If it happens when you're trying to steer it alot on the rocks, could possibly be just a bec is needed.
12-01-2014, 08:51 AM | #5 |
Rock Stacker Join Date: Dec 2013 Location: MN
| Re: Esc question
What tooth pinion and spur gears are you running? As mentioned above, verify that you are not over heating the motor and ESC by putting your finger on both the motor and ESC after running for a while. Could be that you need to change the gearing.
12-06-2014, 09:16 AM | #6 |
| Re: Esc question It usually turns off after a roll or a bounce and its glitchy whenever I turn it on and let it sit, I've tried adjusting the throttle trim and everything I can think of
12-06-2014, 09:26 AM | #7 |
| Re: Esc question
Sounds like a bad connection to me. Turn it on and move the wires around one at a time and see if it glitches/turns off.
12-06-2014, 07:28 PM | #8 |
| Re: Esc question
I checked the connections and though I noticed it before I didn't pay much attention to it but the wires leading from the esc to both the battery and motor were cut pretty close to the esc by the previous owner and where new wires were attatched it's pretty ugly. Also, towards the end of the wires for the battery (where the wires go into the battery connector) it is very flimsy feeling, it feels as though when it's wiggled it's going to fall out. I knew about this but did not think that it could make it glitchy Is there a way to replace the entire wire from the esc or should I spend some money and get a good reliable esc? Here are some pictures of the connections |
12-07-2014, 03:22 PM | #9 |
Pebble Pounder Join Date: Oct 2014 Location: Canada
| Re: Esc question
Hey there, I would start by taking the tape off the connectors towards the ends of the wires. Make sure it has a solid connection. If the wires aren't well connected or the plug itself is very loose that may be the issue. Disconnect it from a battery and inspect. The little cuts on the wire insulation near the ESC don't look like anything to worry about |
12-07-2014, 05:04 PM | #10 |
| Re: Esc question
I will tell you the single most valuable tool for an rc enthusiast is a soldering station, period. With the repairs I've been able to do (that would not have been possible with a pencil type iron) the soldering station has payed for itself many times over. I know you said your 15 but you can always buy a used one. And it is Christmas time after all. One more thing, do yourself a favor and read this.http://www.rctech.net/forum/radio-el...ef-lesson.html Last edited by mrG; 12-08-2014 at 07:32 PM. |
12-09-2014, 07:58 AM | #11 |
Newbie Join Date: Mar 2014 Location: canada
| Re: Esc question
Def remove all tape and trouble shoot as mention above, the axial ae5 is a good cheap replacement
12-09-2014, 08:44 AM | #12 |
Quarry Creeper Join Date: Dec 2012 Location: Remember, wherever you go. There you are.
| Re: Esc question
I've had the same problem and replacing the on/off switch or removing it all together and twist or solder the wires together. Sometimes it's the simplest thing. |
12-09-2014, 08:48 AM | #13 |
| Re: Esc question
Just notice what esc you have. Ae5 would be a great alternative, and there pretty cheep on ebay.
Esc question - Similar Threads | ||||
*** esc question *** | Cmace23 | Electronics | 6 | 05-16-2011 04:34 PM |
esc question | Airmicro | Electronics | 2 | 06-18-2008 06:24 PM |
esc question | 85burbanator | Electronics | 2 | 12-24-2006 10:42 AM |
esc question | TylerV | General Crawlers | 3 | 08-26-2005 11:43 AM |
ESC Question | SupermanWV | Electronics | 3 | 02-16-2005 12:54 PM |
