11-30-2014, 01:03 PM | #1 |
Quarry Creeper Join Date: May 2010 Location: scotland
| gt3c voltage fluctuating
hi i was wondering if anyone had any problems with there gtc3c voltage jumping about my lil bro`s jumps up and down between 3.6.upto 3.9 then back down again and after charging it it doesnt go upto 4.2v like mine does he`s tried two different batterys
11-30-2014, 06:31 PM | #2 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: gt3c voltage fluctuating
Hacked or in hacked? Sounds like an issue with either calibration or wire connections. Does battery read correct voltage in another radio? Has actual voltage been established with volt meter? |
11-30-2014, 07:42 PM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Chuck that piece of shit as far as you can!! I had one...total shit.
12-01-2014, 04:43 AM | #4 |
| Re: gt3c voltage fluctuating unhacked and the battery`s are fine in another controller i forgot to say it was working properly when he first got it but the last few weeks its been doing this and one of the batts is brand new i have`nt tried any of my batts in yet but i will do tomorrow
12-01-2014, 08:00 AM | #5 |
Rock Stacker Join Date: Dec 2013 Location: MN
Has it always been that way or did it just start? I have had mine for about 6 months and have not had this issue. Mine is hacked.
12-01-2014, 08:06 AM | #6 |
Sounds odd......... Never had any issues like that. I've had Gt3b, 3c and gtx3. May want to open up and look for loose or broken battery wire |
12-01-2014, 08:39 AM | #7 | |
| Re: gt3c voltage fluctuating Quote:
iam going todo that tomorrow and see what i can see if anything is wrong | |
12-01-2014, 11:31 PM | #8 |
Let us know what ya find. The wires all in plug from the main board. I would open it completely up and check for smashed or broken battery wires running up to board and or cold solder joints on board. Also look into if there are issues with the power button. They seem to have issues so replacing with small toggle and eliminating the factory switch is a good fix. Could have bad contact causing that to happen. Last edited by JokersWild; 12-01-2014 at 11:33 PM. |
12-02-2014, 04:36 AM | #9 | |
12-05-2014, 12:12 PM | #10 |
Pebble Pounder Join Date: Mar 2014 Location: Raleigh
On all of mine, when you turn them on, the voltage drops a little then recovers back to where it was charged. For example, if it's freshly charged and showing 4.0v. You can turn it off and back on and it might hit 3.8 but recover back to 4 after a second or two. Generally it's pretty stable though and doesn't wander more that +/- 0.2v.
gt3c voltage fluctuating - Similar Threads | ||||
Battery Cell Votage Fluctuating | Zombi | Electronics | 8 | 10-15-2014 02:48 PM |
gt3c | jcsaxial | Electronics | 7 | 08-22-2014 09:00 AM |
Flysky GT3C: First Look | losikid | Electronics | 104 | 12-22-2013 12:25 PM |
GT3C vs GT3B | jeepscx10 | Electronics | 4 | 12-04-2013 09:35 PM |
gt3c lipo? | buggynutt | Electronics | 8 | 03-05-2013 01:25 PM |
