01-31-2005, 02:02 AM | #1 |
Newbie Join Date: Jan 2005 Location: kimberley
| i gotts theez mowterz....
yeah! like i say, these motors i got, theyre huge and and slow and pack lotsa torque... theyre actually permaneny magnet servo motors. they had tach generators but i removed those... anyone know if im safe to run these with a tekin titan? i did some testing on them. wired parallel, at 9.6v (8 cells) no load they draw .75 A. tried to stall them with my fingers and i can get them to draw about 15 A. anyhow, what factors do i need to consider, like, the titan supposedly handles what, 300 A. max? if say, i wanted to run 12 volts... would i be safe? or am i way off and need to lay off the crack? lol |
01-31-2005, 04:15 AM | #2 |
Rock Stacker Join Date: Dec 2004 Location: in limbo
wholy cow those are huge..what rig would you be thinkin of putin them on..would you be running both or jsut one? if you could find out there max draw then you should be able to figure out your exact voltage you can run b4 u blow it...can i take the d5 off you tho |
01-31-2005, 06:21 AM | #3 |
run one motor for 1 minute on the titan on 8 cells and see if gets warm. then try 12 volts. those babies are huge!! use one, and clamp the output shaft with a vice grip, and then measure the stall current. that will give you a good idea of how many watts the motor will suck. |
01-31-2005, 01:02 PM | #4 |
well, these are going in my BIG crawler. it wont actually be big, but the motors will be. i'll probably run krocks. id like it to be shaft driven, so i need to figure out axles. i found a site... stock drive products, its called... they have different gearboxes and stuff like that... anyhow i found what i might need, theyre like a little gearbox with 1 input shaft and 2 outputs. mounting flanges on all 3 sides. all id need to do is fab up some tubes and steering gear. would be cool. oh yeah, that site has everything! gears, screws, chain, etc... they got it all. i'll find a link. oh btw, the d5's already gone, sorry! |
01-31-2005, 05:30 PM | #5 |
Quarry Creeper Join Date: Oct 2004 Location: l.C.
| link
try to get the address for that website, i am interested in what they have. those motors are huge!!! make sure you do a write up on them...
01-31-2005, 07:36 PM | #6 |
Pebble Pounder Join Date: Oct 2004 Location: san francisco
damn dats a big motor if you decide to use them make sure you make a video ;) |
02-02-2005, 07:04 PM | #7 |
those look like brushless with a built in controller |
02-02-2005, 07:08 PM | #8 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
I dont think the performance of those motors (which is still unknown) will be worth the extra weight and size of those motors.
02-02-2005, 07:25 PM | #9 |
well, i beg to differ on that one... the weight and size i mean. well, they got more torque than i'll ever have use for man! sure theyre heavy... so? i want them to be heavy... more traction right? um, nope, they arent brushless, those on the end are called tachometer generators... its just a little generator, with brushes. theyre used to send a signal to the controller, so the controller knows how fast the motors spinning... but i got rid of those, dont need em! and the motors themselves are brushed. heres a link to that site i was talkin about http://www.sdp-si.com/ cool site! they'll even send you catalogues for free!!! which i couldnt resist... im gettin them all! |
02-02-2005, 07:38 PM | #10 | |
I bet you run cement in your wheels too for added weight. | |
02-02-2005, 08:07 PM | #11 |
Rock Crawler Join Date: Apr 2004 Location: Longmont, CO
Have you checked the prices on those stock drive gearboxes??? Hope yours are cheaper than the ones I remember! |
02-02-2005, 09:25 PM | #12 |
hey badger, you got an inferiority complex or what? did you even read the whole thread? it aint going into anything youve ever seen, alright? just cuz i might use krocks means its gotta be a clod or a txt? are people really this dense where you come from????? i need to know! and ace, no i havent checked the prices... im guessing theyre outageously expensive? if thats the case i'll use something else i guess... shitty deal man. i guess i'll use something else... maybe twin force axles? i donno... oh and by the way, the transmission for this thing consists of 2 pinion gears (one for each motor) and one big spur gear, the one i have is 2.5". so... the 2 motors will sit right on the bottom of the chassis, maybe hang down a little lower. the spur gear is the tranny pretty much. one shaft will go between the 2 motors... i thought about using a t-case but that would mean the motors would need to be up high... yeah... well, its slowly coming together. |
02-03-2005, 10:24 AM | #13 | ||
And you are implying that I am dense? Re-read your post boy. Quote:
02-03-2005, 12:51 PM | #14 |
14? sorry. i dont think so. those motors? i got them from work, the scrap yard, where i get whatever i damn well want for nothing. why not stop with the bickering man! holy shit! i come here to this site to have a good time, get some info and feedback. ok, you dont think they'll work. good for you. i think they will. opinions are like assholes, buddy... you know? un****enbelievable man! you'll see when its done. til then keep your comments to yourself. you didnt write the book on crawling so dont act like it.
02-03-2005, 01:09 PM | #15 | ||
02-03-2005, 01:38 PM | #16 |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
Somebody better call the |
02-03-2005, 01:43 PM | #17 |
Thanks SR5Dave! That was a close one... I almost drowned in his tears! |
02-03-2005, 01:49 PM | #18 |
hye guyz, I wunt to rn this moter Itsa 5hpwr moter, to put ti to scales teh shaft is 1 1/8" It ses it will run 220V, do u think i could do 440V w.a big extenshun cord 4 my crawler? |
