12-05-2006, 04:54 PM | #1 |
Quarry Creeper Join Date: Feb 2006 Location: San Jose, Ca
| speed controller output voltage
How do you find out the outpout voltage of a speed controller say the lrp runner or the novak xrs sport? what does bec v stand for in the speed controller specs?
12-05-2006, 05:13 PM | #2 |
BEC stands for Battery Eliminating Circuitry. It produces a voltage for the receiver and servos, as they generally run on a lower voltage than the main pack's. Do you mean the rated voltage for the ESC? The output voltage will be dependant on the batteries. |
12-06-2006, 11:17 AM | #3 |
how about at wide open throttle on lrp runner w/ 3300mah any ballpark voltage spec?
12-06-2006, 11:29 AM | #4 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
If it's a six cell pack, it'll give a max output of 7.2v. Each cell on a nimh or nicd pack produces 1.2v, so multiply the number of cells by 1.2v to find your output voltage.
12-06-2006, 12:19 PM | #5 |
Electronic speed controllers dont regulate voltage, they regulate duty cycle. If your pack is 8 volts charged, it will give 8 volts to the motor whether you have the throttle pegged or cracked open. What are you trying to figure out? |
12-06-2006, 03:49 PM | #6 |
Pebble Pounder Join Date: Nov 2006 Location: 303
most of the sporty speed controls bec's are regulated at 5v-1amp, higher end esc's are rated at 6v-3 amp. Most servo torque specs are at 6v, so you wont get that 238# of torque out of a servo without 6v from the esc.
12-06-2006, 04:14 PM | #7 |
thanks for all the great replies..... I cant say exactly what im trying to figure out.... but I am definetly up to something.... ... if and when i figure it out i will post it up here first. thanks again. |
